Embedded and Microcontrollers
Embedded Forum Interfacing on board microphone sensor in STM32H757I-EVAL
  • Replies 7 replies
  • Subscribers 500 subscribers
  • Views 1524 views
  • STM32H757I-EVAL
  • audio
  • STM32CubeIDE
  • embedded
  • stm32
  • microcontroller
  • audio_interface
priyadarshni_2303
priyadarshni_2303 over 1 year ago
Hi, I am new to STM32 and I am trying to interface on board microphone sensor (MP34DT05TR-A) in STM32H757I-EVAL. The goal is to record audio from the microphones, store it in microSD card and play it back on PC. I am not able to navigate through this; could anyone share some steps that needs to be followed to configure this and to record audio?
    shabaz over 1 year ago +3
    Funnily enough, I'm using the same microphone currently (well, I'm using the slightly tighter-spec MP34DT06). If you're new to this, you'll have an uphill struggle. You need to find a suitable PDM mic…
    Jan Cumps over 1 year ago in reply to phoenixcomm +2
    STM32CubeIDE is Eclipse
    shabaz over 1 year ago in reply to priyadarshni_2303 +1
    I'm not using STM32, I don't have any steps prepared that I could provide. All I can suggest is try some beginner tutorials if you need to learn the IDE (I don't have any specific links).
    Funnily enough, I'm using the same microphone currently (well, I'm using the slightly tighter-spec MP34DT06). If you're new to this, you'll have an uphill struggle. You need to find a suitable PDM mic library (you'll find ARM reference code for that, for instance check out Arduino-Mbed GitHub), plus you need to know about callbacks, and be comfortable messing about with buffer allocations given the amount of RAM you have, and if you plan on recording lengthy audio, then that's even more important. Basically, this is not a beginner project at all.
  • priyadarshni_2303
    priyadarshni_2303 over 1 year ago in reply to shabaz
    Okay, I am trying to code this in STM32CubeIDE. Could you mention steps with with respect to this IDE?
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to priyadarshni_2303
    Why an OTW (off the wall) IDE? you should use Eclipse! on the desktop. I have several instances of Eclipse C, Java, Arduino, and STM32. The tools are all open source, running on this Debian (bookworm) Desktop!
    I got my mic working the other night, it took about 2 evenings work, and wasn't entirely straightforward. But it works. I used Pi Pico. I'll write it up at some point (hopefully next week), but I'm not using a microSD card. I'm simply capturing about 1 second of audio to internal RAM. First impressions, it's quite nice not having to mess with audio levels, nor worrying that the Pico ADC might not be good enough, nor needing to be as concerned about mic cable screening. All those issues eliminated, and can comfortably leave the audio processing in the Pico. An I2S mic would be even better though, less processing to do.
  • Jairo
    Jairo over 1 year ago
    If you are new try to start with an easier project, dont ask people to do your homework
