Embedded and Microcontrollers
Embedded Forum Programmer for ATMEL AT28C256 - 15PU?
  • Replies 8 replies
  • Subscribers 503 subscribers
  • Views 2915 views
  • EEPROM
  • at28c256
  • programmer
SGarciaV
SGarciaV over 8 years ago
Hi all, I am doing some research on EEPROMs and like the ATMEL AT28C256  - 15PU (28 pin DIP).
Looking for programmers, I found this one:
https://www.eetools.com/index.cfm?fuseaction=product.display&product_ID=306
Are there alternate suggestions for other programmers? I really, really just don't have $2,450USD laying about :-)
Thanks! Sgarciav
    shabaz over 8 years ago +1
    I think there are some super-cheap EPROM programmers on ebay etc. They are highly likely to also have modes for 28 series EEPROM since it is programmed nearly the same way, just without the high voltage…
    shabaz over 8 years ago in reply to SGarciaV +1
    Hi Salvador, Definitely the DIY approach is possible, just needs a microcontroller with lots of I/O pins (or some port expander), and a way to get the file from the PC. The datasheet has the details on…
    This one should work, it states 28 series on the list. Just $36: https://www.aliexpress.com/item/SPI-25xx-PCB5-0T-2013-Willem-EPROM-programmer-BIOS009-PIC-support-0-98d12-promotion-clip…
    I think there are some super-cheap EPROM programmers on ebay etc. They are highly likely to also have modes for 28 series EEPROM since it is programmed nearly the same way, just without the high voltage being enabled. Or you could build your own for approx zero cost using a microcontroller dev-board connected to a PC, and a DIL socket for your chip. Or junk sales.. I paid $5 for my programmer (and gave it to a car mechanic since he needed it more than me - for car engine control units).
  • SGarciaV
    SGarciaV over 8 years ago in reply to shabaz
    Thanks Shabaz! I looked at eBay and found a bunch of programmers, but wasn't sure which were compatible with the 28 series EEPROMs.
    I've also considered DIY and have not discarded the idea. I just want to have a better understanding of what is involved and whether it is practical.
    sgarciav
    Hi Salvador,
    Definitely the DIY approach is possible, just needs a microcontroller with lots of I/O pins (or some port expander), and a way to get the file from the PC. The datasheet has the details on this, but there may also be old electronics projects. On ebay there are some old 'Dataman S4' programmers, they will work, but they are about £250 GBP, so still very expensive, they are not worth so much money. If it costs more than £50 GBP, it is worth building your own I think.
  • SGarciaV
    The only downside I see to DIY is that the project would be specific to the 28C256 while a bought product could be compatible with many devices, such as the one that you referenced. Building the programmer would be a project in itself. A while back I built an EPROM reader just because I wanted to. It turned out to be a fun and education endeavor. The big upside was that I found it tobe a fantastic educational experience! I documented it here:
    EPROM Reader Project
    I will consider a DIY, but for now, taking into account that I might need a programmer for other devices, I'll probably go the commercial route. Thanks again! Sgarciav
  • SGarciaV
    Thanks! I am looking into this option.
    Elsewhere I was recommended the TL866CS Universal EPROM/EEPROM Programmer:
    https://www.ebay.com/itm/TL866CS-Universal-EPROM-EEPROM-USB-FLASH-Programmer-MiniPro-BIOS-AVR-AL-PIC-SP/141978692525
    Do you have any suggestions on how I can compare these two products?
    Salvador
    Hi Salvador, I've not used any of these, so if you do try one and it works, please do write up your experiences, in case others wish to do the same. There is still a (small) need to program such devices nowadays, but the requirement is not very common any more.
  • mastmees
    mastmees over 6 years ago
    See Progamming tool for 28C256 EEPROM
