Embedded and Microcontrollers
Pic Microcontrollers Forum Beginners Guide
  • Answers 2 answers
  • Subscribers 237 subscribers
  • Views 1220 views
  • frontpage
Beginners Guide
harisijaz
harisijaz over 9 years ago
Any body guide me to get started with PIC micro controllers . I am absolute beginner and want to learn how to write and upload the codes and make simple projects like interfacing sensors . Thanks in Advance.
  • microcontrollerslab
    0 microcontrollerslab over 9 years ago
    Hi Haris,
    If you are a beginner, first of all I recommend you to find a simple development board for pic microcontroller you can find a list of pic microcontroller development boards here
    http://microcontrollerslab.com/pic-microcontroller-development-boards-features/
    After that, you need a compiler and IDE to write your code for pic microcontroller I recommend you to start with mikro c for pic which is easier to use. Check this link for getting starting with pic microcontroller programming using mikro c for pic
    http://microcontrollerslab.com/pic-microcontroller-programming-c/
    After choosing these start working on pic micro controller tutorials starting from beginners level to advanced level
    here is a very useful source for pic microcontroller tutorials
    http://microcontrollerslab.com/pic-microcontroller-tutorials-beginners/
    I hope it helps you, if you need any help feel free to reply here
    thanks
  • 14rhb
    0 14rhb over 9 years ago
    Another route would be to get yourself a few starter bits:
    • Breadboard
    • Solid core connecting wire + cutters/pliers
    • Small number of resistors (incl. 4k7, 220R )
    • Couple of LEDs
    • Couple of push switches
    • 7805 regulator (or 3v reg depending on PIC chosen), PP3 battery clip, battery ?
    • The Pickit3 programmer
    • A couple of PIC microcontrollers of your choice - DIP packaged and 8 bit
    • A nice plastic box to keep it all in
    The choice of PIC is vast. You'll likely see many beginner articles using the PIC16F84/88. I quite like the PIC16F1509 for general designs as it has a good range of built in peripherals. It also contains Configurable Logic Cells (CLC) which can be setup to drive the WS2812 addressable LEDs using hardware.
