Embedded and Microcontrollers
Pic Microcontrollers Forum PIC16F84 programing question.
  • Subscribers 234 subscribers
  • Views 708 views
codar
codar over 3 years ago
All new to me these micros.... giv mi' the inside of a telly or a transmitter any day.  I have a Pic3 and related Pic3 installation software... and Hex code etc. and  I'm  using a ZIF extender board to couple the Chip to the pic, with the shorting/linking pins configured as per instructions on the back.
I would sooner ask before 'blowing things'.  MCLR (pin4) with the shorting pin in situ places this pin onto the +ve line, all the info I come across shows a 10K resistor between +ve and pin 4...... do I leave the link out and insert a 10K or go ahead leaving pin 4 connected to the +ve line? The chip being powered via PIC3. Thought I'd try my hand with MCU's.
Thanks, Dave
    shabaz over 3 years ago +5
    Hi, The answer is in the PIC16F84 datasheet, section 8.4. It describes how you can use that pin in the text there (it refers to resistor and resistor-less options), plus there's an optional diagram there…
    The answer is in the PIC16F84 datasheet, section 8.4. It describes how you can use that pin in the text there (it refers to resistor and resistor-less options), plus there's an optional diagram there.
    In general, it's better to tie pins to a supply through a resistor if you think you may need to pull the pin to a different logic level easily, but another method is to have a shorting link.
    • Vote Up +5 Vote Down
