Ask an Expert Forum TB6612 and Esp32
  • Subscribers 328 subscribers
  • Views 3751 views
See a helpful answer?
TB6612 and Esp32
electronicslearner101
electronicslearner101 over 4 years ago
Hi there! I am wondering how should I use my Esp32 Wrover Module to add WiFi commands to a car with the TB6612fng Motor Driver. I am using the Blynk app to send signals to my ESP32. I got that working but I am struggling to figure out how should I use the Driver with my ESP32. Thanks for the help! (I also have access to an Arduino Uno in case that helps)
  • fmilburn
    fmilburn over 4 years ago in reply to electronicslearner101 +3
    Hello Jeffrey, You will need to post the error message to get help. Presumably you are using an Arduino library and that may use different pins or be referencing an Arduino command that does not exist…
  • makerkaren
    makerkaren over 4 years ago +2
    Sorry, I’ve never used one so I’m not much help there.
  • electronicslearner101
    electronicslearner101 over 4 years ago in reply to makerkaren +2
    Oh okay, no problem. Big fan by the way You should definitely learn and make projects about the ESP32. It’s like a better version of an Arduino with GPIO pins that can do all sorts of things, built in…
    I keep getting an Error Message that states “Error Compiling for board Esp32 Wrover Module”….imageimage
  • makerkaren
    Oh okay, no problem. Big fan by the way image You should definitely learn and make projects about the ESP32. It’s like a better version of an Arduino with GPIO pins that can do all sorts of things, built in camera, WiFi and Bluetooth capabilities. It’s AWESOME
    Oh okay, no problem. Big fan by the way image You should definitely learn and make projects about the ESP32. It’s like a better version of an Arduino with GPIO pins that can do all sorts of things, built in camera, WiFi and Bluetooth capabilities. It’s AWESOME. Thank you for your amazing videos and have a great night/day!
  • fmilburn
    Hello Jeffrey,
    You will need to post the error message to get help. Presumably you are using an Arduino library and that may use different pins or be referencing an Arduino command that does not exist for the ESP32 implementation.  It is relatively simple to write your own motor control software.  For each motor channel there is a PWM pin to control speed by varying duty.  There are also two pins used per channel to control motor direction.
    edit:  does it compile on the Uno without errors?
  • makerkaren
    makerkaren over 4 years ago in reply to electronicslearner101
    I keep hearing that! That's why I picked up a couple ESPs, but honestly I can't remember which model number. Heh.
