Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17434 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
  • nickgray
    nickgray over 16 years ago in reply to e14 Contributor
    I am sorry, but I am not familiar with Power Inverters. I suggest you post your enquiry under Power. I wish you luck.
  • nickgray
    While I have not found the technical article I wrote in 1998 or 1999, I have found the posting of the document used for an on-line seminar on this subject that I did back in 2002. You may find it at www.national.com/appinfo/adc/files/controlling_noise.pdf. I believe that this will provide the information you need.
    Hi Nick,
    I'm interested in a Stand alone High Quality Codec with SPDIF output. Any reccomendations?
  • nickgray
    I do not know what you mean by "High Quality" as this means different things to different people. However, the IDT STAC9750 (5V) and the STAC9751 (3.3V) Codecs are very good products that might suit your needs. Other devices to examine are the PCM3052A from TI and the UDA1355H from Philips, the STAC9750/51/56/57/66/67 from Sigmatel and the WM9707 and WM9710 from Wolfson. I hope one of these suits your needs.
  • nickgray
    I have written a Blog about Printed Circuit Board layout. You may see it at http://www.element-14.com/community/groups/data-converters/blog/2010/09/18/printed-circuit-board-layout. The whole subject could make a small book, but what I have in this
    Blog should help a lot.
  • WestfW
    WestfW over 16 years ago
    I've been wondering if there are "semi-smart" DACs in the audio frequency range?
    What I had in mind was something like a modern uart; 64bytes of FIFO and a rate
    generator, so you could tell it "convert this stream of digital info to analog at 8k samples
    per second, but only interrrupt me every 5ms so I can fill up the FIFO via some high-speed
    interface, rather than every 125 us (one sample.)
    I guess usually this is done by putting a smarter processor on the other side (one with DMA
    capabilities and specialized interfaces like IIS(?)), but I was hoping for something usable
    with simpler microcontrollers.
    For that matter, are there any audio-oriented CPU/DAC combos that lie somewhere in
    between an ISD chip and a consumer MP3 device?
    Bill W
  • nickgray
    nickgray over 16 years ago in reply to WestfW
    What you are requesting would be a great product, but I am not aware that anything like it exists. Austria Microsystems does have a AS3531 that is preliminary or very new that MIGHT do this, but I am not familiar with it other than the fact that it exists. It is called a "Mobile Entertainment IC" and can be found at http://www.austriamicrosystems.com/eng/Products/Mobile-Entertainment/Mobile-Entertainment-Players/AS3531. The data sheet is not on the web site and must be requested (can be done from this site), which tells me that it probably is not yet released. Please let me know if you find that this device does what you want.
    I am sorry that I can not be of more help.
    e14 Contributor over 16 years ago in reply to WestfW
    Bill,
    I also am not aware of any product that does what you describe.   Nicholas Gray has already pointed you to Austriamicrosystems as a possibility.  I am sure you are aware of the necessity to keep the effective audio sample rate the same from input to the DAC to the output of the high speed interface, else the audio will sound funny or not at all.
    Ken
    e14 Contributor over 16 years ago in reply to nickgray
    thanks for the reply. Oversampling, low noise, great audio quality...
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Phil,
    AKM Semiconductor has a wide range of very high quality audio ADC, DAC, Codec, and SPDIF devices.  A link to the SPDIF parts is here:
    http://www.akm.com/prod-spdif.asp
    But check out all their stuff for what you are needing.
    Ken
