Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17128 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
  • nickgray
    nickgray over 15 years ago in reply to JohnDSiviter
    I do not know just what you mean by "high quality" because this means different things to different people. However, here are some 16-bit DACs with I2C interface:
    AK4440 octal DAC from AKM Semiconductor; AD5629R and AD5669R octal DACs and AD5543 quad DACs from Analog Devices; LTC2605 and LTC2657 octal DACs from Linear Technology and the DAC8574 quad DAC from Texax Instruments. The AKM device is 24 bits, while the others are 16-bits.
    - Nicholas "Nick" Gray
    e14 Contributor over 15 years ago in reply to nickgray
    Thanks Nick,
    Although this part does have a high output impedance as you point out, the input capacitance of the ADC is only 15 pF (typ) which gives a time constant of only 9 nS for 600 ohms; I'm not sure how this would translate to the 11 mS settling I'm seeing.  Looking at this another way, say I need a 4 volt step on the output.  According to  the data sheet, the LMP2011 can source about 9mA at 4V.  Thus,  i=C*dv/dt=>
         dt=15pF*4/.009=6.7nS.  That's a million times less than 11mS.
    And it doesn't look like a 'normal' settling time issue where you would see an overshoot and some damped ringing-the output stays 'stuck' at some constant level for 11mS, and then rises to the 'correct' value.  It looks more like what you'd see when an opamp recovers from saturation (the output is well below saturation-about 300mV with a 5V supply).
    Ironically, National says in their data sheet: "The LMP201x is a great choce for an amplifer stage immediately before the input fo an ADC."
    I will definitely look into alternate opamps.  Also, I think I can live with setting my sample rate lower so that I can accomodate the long settling time.  At this point I'm more concerned about WHY this didn't work as expected; in my experience, when you don't understand a problem but think you've found a fix, you haven't really.
    Barry
    Sir,
    Currently i am using Proteus 7.4SP3 to simulate the AD633 multiplier.  The two input is a trend of pulses and i want to get the output. The  problem is that it occur 2 warnings which is then stopped my simulation.
    1. [SPICE] DELMIN increased to 1.11022e-016 due to lack of time precision
    2. [SPICE] TRAN: Timestep too small; timestep = 0: trouble with node #v:u1:nc#branch
    I had attached the jpg for you to refer. Please help and commend about the problem. I need your help very much. Thanks =)
    Dear Sir,
    Can you explain to me what is the function of this device  DG201 CMOS QUAD SPST ANALOG SWITCH? I had search using google or yahoo  search machine but still cant find any site explaining this device except the DATASHEET. The DATASHEET did not explain in details the theory behind it. So  if you know what is it please tell me or paste the link for me here.Thanks..
    Hi Nick
    Really appreciated that u replied my message.I'm not sure whether we are able to wait for the launching of this chip but that will be wonderful if this chip is made available in the market soon. Our's is an asia based company mainly focusing on bio equip such as dialyser but the targeted annual volume is still in consideration. i would like to once again thank you on this reply and hope to receive more information on the new chip.
    Best Regards
    Alvin
  • JohnDSiviter
    JohnDSiviter over 15 years ago in reply to e14 Contributor
    Hi Steven,
    A tip: just type it into Google, I did that and found: http://www.intersil.com/products/deviceinfo.asp?pn=dg201
    SPST = Single Pole, Single Throw (1 in, 1 out).
    Its a simple voltage controlled switch.
    John.
  • nickgray
    nickgray over 15 years ago in reply to e14 Contributor
    Hi, Stephen -
    I am not familiar with Proteus, but I do suggest that you contact Lamcenter Electronics, the supplier of this software, and ask them. They do have a user's forum that may be able to help. See them at http://support.labcenter.co.uk/forums/viewforum.php?f=9&sid=9c3487a09b6bb86720bd111886391d57.
    I have attached hera an Excel spreadsheet which simylates the AD633, based upon information from the AD633 data sheet. This spreadsheet generates random inputs each time you change anything. The easiest way to do this is to select an unused cell and press the DELETE key. I hope it helps.
    AD633_Simulation.xlsAD633_Simulation.xls
  • nickgray
    Hi, Stephen -
    The function of an analog switch is basically the same as a mechanical relay, except that the analog switch is a solid state device using MOSFETs. The analog switch generally does have a higher input to output capacitance than does a mechanical relay, which allows high frequency signals to pass when the switchis "open". A good tutorial on the analog switch can be found at www.analog.com/static/imported-files/tutorials/MT-088.pdf.
  • nickgray
    Hello, Alvin -
    If you will please send me the name of the company needing the load cell Signal Conditioning Chip and your email address, I will be sure that you have the information on this device as soon as it is available. When you have an estimate of the expected annual usage, please let me know that as well.
    I had said that I knew of no sensor signal conditioning chip available now, but I found that that a company in Germany named ZMD is making some, although they are not at all as good as the solution I told you about that will be available in a few months. You can go to the ZMD web site at http://www.zmdi.com/.
    Best Regards,
  • nickgray
    Barry -
    I phoned a friend of my in the amplifiers group of National Semiconductor and he told me that the LMP2011 has a lot of capacitance associated with it (it is a chopper-stabilized amplifier) and the overload recovery time is typically 50 ms. See data sheet pages 3 and 4 for overload recovery time specifications. The key to getting what you need is to insure that the part never goes into overload. That is, keep the device operating within its linear range. This implies ensuring that the input does not momentarily make a jump so large that the amplifier has difficulty following it, and being sure that the output never saturates. I suggest you may need an amplifier that is NOT chopper stabilized, but such an amplifier would have a larger input offset voltage.
    - Nick Gray
    Barry -
    - Nick Gray
