Ask an Expert Forum Have a question about ADCs or DACs? Ask our Expert, Nick Gray
  • Replies 118 replies
  • Subscribers 345 subscribers
  • Views 17131 views
  • expert
  • nick_gray
  • power
See a helpful answer?
ChristyZ
ChristyZ over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Nick Gray
Nicholas Gray
Nicholas has worked in the Semiconductor industry for over 30 years and has authored a number of published articles about data converters (ADCs and DACs) and signal integrity issues.
  • nickgray
    nickgray over 14 years ago in reply to e14 Contributor +1
    Hi, Ben, A couple of ADCs that should do well in your application with Hall Effect sensors are the ADS1146 and the ADS1255, both from Texas Instruments. I am sure that other suppliers probably have suitable…
  • nickgray
    nickgray over 14 years ago in reply to YT2095 +1
    The reason that you picked up radio signals when connecting a long wire antenna to the input is because the ADC had an input bandwidth that could pick up those signals. The sampling action of the ADC then…
    Hi Nick,
    I'm looking for ADC wich complete this conditions :
    fully differential for 1.3Vptp signal
    common voltage 2.5V
    speed > 250KSPS
    useful resolution > 16bits
    package as small as possible
    Could you help me to find it ?
    Matthieu
  • nickgray
    nickgray over 15 years ago in reply to e14 Contributor
    Hi, Matrthieu -
    I assume that, by "common voltage 2.5V" you mean that you want to work with a 2.5V input common mode voltage.
    I have looked at a few ADCs and the only one that I have found that I am sure will suit all of your needs is the ADC161S626 from National Semiconcuctor. It is a 16-bit, 250ksps ADC that comes in an MSOP-10 package that is 3 x 5 mm in size to the lead tips. It can accomodate a 1.3V peak-to-peak input. I think you will be happy with this device.
    Nicholas "Nick" Gray
    Hi!
    For an audio application, I am thinking about using the TI PCM1792ADB.PCM1792ADB. DAC. Its datasheet (http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=pcm1792a&fileType=pdf) suggests a schematic in Figure 36 (Page 35) for converting the differential current output to single-ended voltage output using NE5534NE5534 and LT1028 op-amps on +-15V rails.
    (a) Is it possible to reach a similar performance without the negative supply rail?
    (b) Would the  LTC6252 / LTC6253 op-amps run from 0V and 5V be a sensible choice, or should I use different op-amps?
    (c) Will I have to make larger changes in the schematic, or are the op-amps drop-in replaceable?
    Spida
  • nickgray
    Hello Spida,
    Yes, it is possible to reach similar performance without a negative supply rail, but believe that 5V is insufficient voltage for this circuit because 2Vrms output of this circuit is the same as 5.66V peak-to-peak. However, if you use a rail-to-rail op-amps and 402 Ohms for the feedback resistors of U1 and U2, you can get about 1Vrms from the circuit. However, even rail-to-rail amplifiers will distort the signal as you approach the rails, so I am not sure that you can get the same performance with them.
    As a result of your and other questions I have seen over the years, I wrote a blog on doing this. Please see it at http://www.element-14.com/community/blogs/analog-by-nickgray/2010/12/01/going-from-bipolar-to-unipolar-supplies.
    - Nick Gray
  • sukandar
    sukandar over 15 years ago
    Dear Sir,
    could you tell me if there is any difference between the  ADS8344EBADS8344EB and the  ADS8344EBG4ADS8344EBG4
    I can't seem to figure out the difference on TI's website.
    Both are RoHS compliant, same package, same temperature rating, same performance....
    Kartadinata
  • nickgray
    nickgray over 15 years ago in reply to sukandar
    I tried to find the answer on TI's web page and, as you said, the answer is not there. At http://focus.ti.com/quality/docs/searchbyopn.tsp?templateId=5909&navigationId=11220&orderablePartNo=ADS8344EB&pnType=A I did find an indication that the  ADS8344EBG4ADS8344EBG4 is lead free and the  ADS8344EBADS8344EB is not but everything else says they are both lead free I am still trying to find information on this and will let you know what I find
    - Nick Gray
    Hi, Iam working on a kenwood ts820s ham radio, and i think i have a bad relay. I am trying to find a omron 300 ohm type mh4p tri-2. the connectors are dark and burnt looking, can you help me. Mike.
  • nickgray
    Hello, Mike -
    I have tried to look up the Omron relay you called out, but was unable to find anything about it. I am not an expert in relays and suggest that you as your question of Aiman Kiwan or maybe Ronnie Haiduk. Aiman is an expert in both solid state and mechanical relays and Ronnie is an expert in solid state relays. I do not know into which category the relay you want falls.
    Alsom with burnt connectors there may be something else that caused the connectors to burn. The relay may or may not be bad.
    - Nick Gray
  • nickgray
    Hello Sukandar-
    I am sorry that this took me so long, but I have finally found that the "G4" suffix is left over from the days of ROHS vs. non-ROHS compliant parts and the G4 was to indicate prodouct that was ROHS compliant. Today the non G4 and the G4 parts are the same as everything is ROHS compliant.
    - Nick Gray
  • viantro22
    viantro22 over 15 years ago
    HI !
    I  PUSH  "LOGIN"  IN  YOUR  POST   NOTHING  NO  HAPPEN ......IN  YOUR   POST.
    ATTEMPT   SEND   QUESTION  FOR   NICK  GRAY  CALL    DEMAND  TO   INCLUDE   PEOPLE   FROM
    LIST...?
    ALL   TANGLED  AND  COMPLICATED  OR   I   SOMETHIING   NO  UNDERSTAND.
    REGARDS
    VIANTRO22
