Ask an Expert Forum Have a question about radio or wireless communication?  Ask me!
  • Replies 84 replies
  • Subscribers 347 subscribers
  • Views 9794 views
  • communications
  • pinter_electronics_consultants
  • expert
  • radio
  • wireless
  • chris_pinter
See a helpful answer?
Chris_Pinter
Chris_Pinter over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Communications in the element14 Community Wireless Communications Technology group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Christopher Pinter
As the founder and President of Pinter Electronics Consultants Chris has been instrumental in developing the business from its inception in 2005 to its current status.  He has over 15 years of experience in radio and wireless communication hardware design and product development. Chris graduated from the Okanagan University with a diploma in Electronic Engineering Technology and the British Columbia Institute of Technology with a Bachelor of Technology in Electronics.
  • Chris_Pinter
    Chris_Pinter over 12 years ago in reply to e14 Contributor
    Hello Doumandji,
    Sorry for not replying earlier.  Had some issue with email.
    I worked on a number of projects involving 100's of nodes and this can become complicated depending on the requirement of your system.
    I will need to look at your requirements a little more.  Please email me directly with your questions.
    www.pinterec.ca
  • Chris_Pinter
    Is this a toy you are building?  Is it a small project for your own use or will you be selling the system?  I need to know in order to point to the right resources.
    I am not sure of your capabilities. So I need more info.
    Chris Pinter
    www.pinterec.ca
  • Chris_Pinter
    Hello Nikhil,
    Well....you can do it many ways... it depends really on what you want.  Most engineering projects start with a requirements document then a design concept.  I understand this is a university project so my advice would be to focus your study on one particular issue and use modules everywhere else.
    What I mean to say is.....  your project must demonstrate your new skills in one area of study.  I imagine this is not intended to be a wireless projects.  So.. get the simplest wireless solution you can find so you are not spending your time "developing" a minor part of your project.  Wireless technology can be complicated to eliminate the development risk as much as you can.
    WiFi will not be the easiest.  You will want to go with a bluetooth or 2.4GHz module.  use the evaluation kits and wire it up as a demo.
    Hope this helps,
    Chris Pinter
    www.pinterec.ca
    I am a hobbyist and would like to build a radio receiver. Is there a basic circuit diagram available?
    Do you want to build one from scratch Steve?
    You can build one from discrete components down to single transistor level
    or get a chip with most of the parts integrated into it.
    Then you need to consider whether it's for medium/long wave, FM of even VHF
    air band etc
    Allan
    http://www.radiomuseum.co.uk
  • Chris_Pinter
    HI Steve,
    A good place to start is using a kit.
    Electronic Kits, Electronic Hobby Kits, Electronic Kit
    this will give you the basics.
    keep your frequency low and you should do ok. Try to stay under 400 MHZ.
    IF you want to make a 2.4GHz radio you need to go to a module.  That is what the pros use.  Texas Instruments is a good choice for modules.
    good luck,
    Chris Pinter
    www.pinterec.ca
    Yes, I would like to start with a very simple design and build it from scratch if possible.   I always wanted to build one since childhood.  I'm learning alot about electronics in general,  but there's alot  to learn....
    Sent from Yahoo Mail on Android
    shabaz over 12 years ago in reply to e14 Contributor
    Hi Allan,
    You have a really great website. Do you own all that gear?
    Have you considered higher-res images on your site, since I bet many people would be interested in seeing all your items. However I can imagine it would take a very long time to photograph all that : (
    Still, I enjoyed visiting your site.
  • Problemchild
    Problemchild over 12 years ago in reply to shabaz
    Yes definitely, more pics video and Audio would be fantastic .
    A series showing a vlve radio repair would go well at least here ...Cheers image
    e14 Contributor over 12 years ago in reply to Problemchild
    Yes, I own all that stuff folks
    Sorry about the definition of the pictures. The site was designed when all
    we had was dial-up and now I'm too busy repairing circuit boards for lifts.
    It would be interesting to build a receiver from scratch.
    I used to do this back in the 1950s, of course with valves in those days.
    Something different would be a single valve super-regenerative receiver.
    This could tune the FM band and the air band.
    I built several using a 955 acorn triode
    The super-regens don't mind if its FM or AM and they are very sensitive..
    just a few feet of wire for an aerial.
    I just found this site for circuits
    http://myweb.tiscali.co.uk/norcimradiocontrol/Radio17.htm
    I'm just about to publish the repair of a TF2008 signal generator, although
    not valves I'm afraid, although I did include on my website the repair of a
    marine valve equipment.
    Cheers
    Allan G3PIY
