Ask an Expert Forum Ask the Expert: Fredy Klammsteiner - Sensor Application Expert
  • Subscribers 340 subscribers
  • Views 970 views
  • experts
  • ask_an_expert
  • ask_the_expert
  • sensor
See a helpful answer?
patkelly
patkelly over 14 years ago
Fredy Klammsteiner is Custom Product Manager at Innovative Sensor Technologyimage
Fredy Klammsteiner is Custom Product Manager at Innovative Sensor Technology, consulting customers with special sensor application requirements in temperature, flow, humidity and conductivity. With a background as El. Eng. FH, Fredy joined IST in 2006 as Area Sales Manager for Eastern Europe, East Germany, Scandinavia and Russia and as Product Manager for TSic. In 2009 he became Head of Custom Products at IST.
Your title at IST?
Custom product manager
What is your education background?
El. Eng. FH
What are the areas of expertise within IST?
Consultancy of customers with special sensor application requirements, sales in several countries, product management of TSic sensor series, project management of custom sensors for temperature, flow, humidity, conductivity
And a short description of your work history?
2006 - 2009: Area Sales Manager Eastern Europe, East Germany, Scandinavia, Russia
2009 to date: Head of custom products
To ask Fredy a question reply to this discussion thread. Don't forget you will need to login or register to post your question
  • Eavesdropper
    Eavesdropper over 14 years ago
    Mr. Klammsteiner,
    I need a small pressure sensor to use internally on a gas pressure system. Suggestions?
    Due to the sealed system, how could I pass the data from the sensor to an external system?
    E
  • Fredy_Klammsteiner
    Fredy_Klammsteiner over 14 years ago in reply to Eavesdropper
    Dear Eavesdropper
    We are a producer of thin film elements for temperature, humidity, flow and conductivity. We don't produce any pressure sensors. But Endress + Hauser produces pressure sensors for gas and liquid applications:
    http://www.uk.endress.com/#products/~products-instruments-pressure-measurement
    I'me sure you will get help there.
    Best regards
    Fredy Klammsteiner
  • Vulcan
    Vulcan over 13 years ago in reply to Fredy_Klammsteiner
    Hi Fredy,
    I'm trying to measure a low airflow - between 0 and 5m/s.
    Can you suggest the correct sensor and also some links to some microcontroller software to analyse sensor output?
    Alternatively, is there a bit more applications info available to the analog circuitry on the IST website?
    Thanks.
    i have msp430fg4618 controller. i want to read hyt-221 sensor useing i2c.i interfaced sensor and useing IAR develop following code but its not work.NACK is coming from sensor.
    //   MSP430xG461x Demo - USCI_B0 I2C Master TX multiple bytes to MSP430 Slave
    //   Description: This demo connects two MSP430's via the I2C bus. The master
    //   transmits to the slave. This is the master code. It continuously
    //   transmits an array of data and demonstrates how to implement an I2C
    //   master transmitter sending multiple bytes using the USCI_B0 TX interrupt.
    //   ACLK = 32kHz, MCLK = SMCLK = TACLK = BRCLK = 1MHz
    //                MSP430xG461x     10k  10k    MSP430xG461x
    //                    slave         |    |        master
    //            -|XIN  P3.1/UCB0SDA|<-|---+->|P3.1/UCB0SDA  XIN|-
    //       32kHz |                 |  |      |                 | 32kHz
    //            -|XOUT             |  |      |             XOUT|-
    //             |     P3.2/UCB0SCL|<-+----->|P3.2/UCB0SCL     |
    //   Andreas Dannenberg/ M. Mitchell
    //   Texas Instruments Inc.
    //   October 2006
    //   Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
    #include "msp430xG46x.h"
    volatile unsigned char k,d,t,*prxdata,s,txdatactr;
    volatile unsigned char data,rxdatactr,rxdata[5]={0,0,0,0,0},sdatactr;
    int i;
    void delay(int i)
      while(i!=0)
        i--;
    void main(void)
      WDTCTL = WDTPW + WDTHOLD;
    delay(60000);
      P3SEL |= 0x06;
      P2SEL |=0x00;
      P5SEL =0x00;
      P5DIR =0x02;
      P2DIR |= 0x06;
      P5OUT=0x00;
       UCB0CTL1 |= UCSWRST;
      UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;
      UCB0CTL1 = UCSSEL_2 + UCSWRST;
      UCB0BR0 = 10;
      UCB0BR1 = 0;
      UCB0I2CSA = 0x29;
    UCB0I2CIE =0x09;
      UCB0CTL1 &= ~UCSWRST;
      P5OUT |=0x02;
      while (1)
         P2OUT=0x04;
        delay(60000);
        P2OUT=0x00;
        delay(60000);
        txdatactr=1;
        IE2 |= UCB0TXIE;
        k=1;
        __bis_SR_register(GIE);
        UCB0CTL1 |= UCTR + UCTXSTT;
          while(k);
          while (UCB0CTL1 & UCTXSTP);
        P2OUT=0x04;
        delay(60000);
        P2OUT=0x00;
        delay(60000);
        t=1;
        rxdatactr=3;
        prxdata= &rxdata[0];
        IE2 |= UCB0RXIE;
         UCB0CTL1 &= ~UCTR;
        UCB0CTL1 |= UCTXSTT;
        __bis_SR_register(CPUOFF + GIE);
    //UCB0CTL1 &= ~UCTXSTP;
    // The USCIAB0TX_ISR is structured such that it can be used to transmit any
    // number of bytes by pre-loading TXByteCtr with the byte count. Also, TXData
    // points to the next byte to transmit.
    #pragma vector = USCIAB0TX_VECTOR
    __interrupt void USCIAB0TX_ISR(void)
      if(k==1)
                if(txdatactr)
                UCB0TXBUF=0x28;
                txdatactr--;
            else
                   UCB0CTL1 |= UCTXSTP;
                   //UCB0CTL1 &= ~UCTXSTT;
                   IFG2 &= ~UCB0TXIFG;
                   IE2 &= ~UCB0TXIE;
                   k=0;
                    //__bic_SR_register_on_exit(CPUOFF);
       if(t==1)
      if (rxdatactr)
       *prxdata=UCB0RXBUF;
       if((IFG2 & UCB0RXIFG)==0)
          P5OUT |=0x02;
       if(rxdatactr==1)
        rxdatactr--;
        prxdata++;
      else
        *prxdata=UCB0RXBUF;
        // UCB0CTL1 |= UCTXSTP;
       IE2 &= ~UCB0RXIE;
        t=0;
    #pragma vector=USCIAB0RX_VECTOR
    __interrupt void USCIA0RX_ISR (void)
      if((UCB0STAT && UCNACKIFG)==1)
        P5OUT =0x00;
        UCB0STAT &=~UCNACKIFG;
      if((UCB0STAT & UCALIFG)==1)
        P5OUT |=0x00;
    so plz help me///////
    Fredy_Klammsteiner over 13 years ago in reply to e14 Contributor
    Dear karan patel
    Could you please send this request to my email address fredy.klammsteiner@ist-ag.com. I will forward it to our responsible person at IST AG.
    Thanks and best regards
    Fredy Klammsteiner
