Ask an Expert Forum help with the flow sensor FS5
  • Replies 22 replies
  • Subscribers 322 subscribers
  • Views 4149 views
See a helpful answer?
hi please i need help how to use my flow sensor FS5.
would like to measure flow of gas so i bought the FS5 but now i am reading the datasheet that i download from the webside but its not helping.
if anyone have use it befor can i have your circuit diagram please.
Regards
    dougw over 12 years ago +2
    Hi Leonel, A reference circuit is included in the data sheet: http://www.farnell.com/datasheets/484569.pdf You may need to reduce or offset the output voltage. Here is a link to an example: http://dl.dropboxusercontent…
    dougw over 12 years ago in reply to Former Member +2
    Hi Leonel, The sensor includes the heater (Rs is the Sensor Resistance and RH is the heater resistance in the circuit - both of these resistors are stuck together as part of the sensor you have). One wire…
    Former Member over 12 years ago in reply to dougw +1
    hi Doug Thanks for your response. I saw the 2nd link in your response.I can see circuit diagram its exactly something like that that am looking for but have a concern: Its written sensor is it the FS5…
    Hi Leonel,
    http://dl.dropboxusercontent.com/u/7549930/aaSchematic2-diffAmp.png
    and a discussion:
    output - arduino thermal anemometer - Electrical Engineering Stack Exchange
    If you cannot build it, you might be able to use the evaluation module from Farnel:
    160.00001 - IST INNOVATIVE SENSOR TECHNOLOGY - EVALUATION BOARD, FOR FS5 FLOW | Farnell UK
    http://www.farnell.com/datasheets/1702754.pdf
    Doug
    hi Doug
    Its written sensor is it the FS5? and see heater as a block do need to buy a heater also? or its just the name of that leg of the sensor.
    Please be sore explicite please
    Waiting to hear from you.
    Leonel
    Hi Leonel,
    The sensor includes the heater (Rs is the Sensor Resistance and RH is the heater resistance in the circuit - both of these resistors are stuck together as part of the sensor you have). One wire goes to the heater, one wire goes to the sense resistor and one wire is ground - internally connected to the other end of both resistors.
    The circuit uses feedback from the sensor resistance to keep the heater at a constant temperature. The output of the circuit indicates how much voltage is needed to keep the heater at this temperature. As more mass flow takes heat away from the sensor, more voltage is needed to maintain the same temperature, so the output goes up as the mass flow increases.
    Doug
    Hi ,thank you so  much for your help.
    Can you advise me on an altenative op amp as I cant find the LT1635  on RScomponent who our supplier here..
    I wanted to supply my circuit with a small battery so I am wondering if I can't use 9V instead of that 12V.
    In final have you build this circuit and it work 100%?
    Thank you
    Leonel
    You could use a TLV271 (or a TLV272 which could replace both op-amps).
    I don't know if 9 v is sufficient to supply the heater in this circuit, you may need to reduce R3 and R4.
    I have not tried it...
    Former Member over 11 years ago in reply to dougw
    hi Doug
    I try the circuit as you sent me but with no success.
    Can you suggest an alternative circuit or which 12 volt battery i should use.maybe the 12 volt battery doesn't have enough current to heat up the sensor?
    please can you connect me with somebody who have use the sensor before
    Big thank you again
    dougw over 11 years ago in reply to Former Member
    When you connect it up, what voltage is on each pin of the transistor?
    And each pin of each op-amp?
    hi,sorry for the late response but apparently i am using the FS1 not FS5 can i use the same circuit. when i look at the datasheet of the FS1 there is a circuit on it different to the FS5. But on that circuit those resistors doesn't have value.
    please help
    leonel
    The FS5 circuit should work fine for the FS1 sensor.
    With a 12 V supply, the heater won't draw more than 120 mA, so any battery should be adequate.
    If you measure all the voltages on the transistor and op-amp, we could help diagnose the issue.
    hi,
    here are the measurement on the voltage on the transistor : pin1 and pin2 = 0.6Vdc
    on the oscilloscope i can see a waveform that its moving as i change the flow of the gas that i am sending to the sensor. but i have to reduce the volt per division to the smaller one to see that change.
    I don't know if that its just noise or its the signal that i am suposse to see and i have to filter it.
    Please guide me
    leonel
