Ask an Expert Forum Difference between Mounting type Surface Mount and PCB
  • Subscribers 339 subscribers
  • Views 659 views
See a helpful answer?
Hello everyone,
I am a fresher, and I need to buy some SMP connector. I found there are two types of connect mounting: surface mount and PCB.
Could anyone please tell me what the difference between these two types? Thanks ahead.     (Does "PCB" mount type require to leave 4 holes for its foots when designing my PCB?)
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago
    There both PCB
    Difference is typically that one uses through hole as you describe, this would be for the electrical connectors and sometimes additional supporting connections, either way they all go through the PCB and make a very strong join
    Surface mount are just that, there are no holes through the board and they are soldered to the PCB tracks on the side there mounted on
    Strength is often that of the PCB track adhering to the board, not the mechanical strength of the through hole connection
    The nice thing about the SMD connectors is they can be re-flow soldered along with the other chips and discrete components rather than a separate post reflow operation
    Regards
    Peter
    e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    Thanks Peter! Your explanation is very clear!
    Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    your welcome
