Ask an Expert Forum Digital PI (Pulse Induction) metal detector.
  • Subscribers 328 subscribers
  • Views 2331 views
  • analog-to-digital
  • microcontrollers
  • metal
See a helpful answer?
I want to build a digital PI (Pulse Induction) metal detector. Which components may be the best for this? I think I'll need a fast and precise AD converter and a fast micro controller to measure the voltage decay and then compare with a normal curve without metal present. ¿Am I in the right way?
Thanks in advance!
    michaelkellett over 10 years ago in reply to bobalexander +1
    I think that for the OP, PI means Pulse Induction not RaspberryPi. But never mind - the board you suggest is quite nice but based on an older STM32 processor which can't convert as fast as some of the…
  • bobalexander
    bobalexander over 10 years ago in reply to michaelkellett +1
    Good point - I completely missed that! I was under the impression that Pulse Induction is not a great option as you can never discriminate out iron. Perhaps that is what the OP is wanting to detect though…
    0 michaelkellett over 10 years ago
    You've double posted this  - I've answered it in the Ben Heck group where I saw it first - you really shouldn't double post.
    0 Former Member over 10 years ago in reply to michaelkellett
    You are right sorry about that and thanks a lot.
  • bobalexander
    0 bobalexander over 10 years ago
    You could add a ARMinARM board if you are wanting to utilize the Pi as some kind of interface:
    onandoffables / hardware / arminarm / board
    The  STM32 ARM Cortex-M3 microcontroller 'backpack' would let you perform all the signal sensing and low level processing just passing off data to the Pi...
    Most metal detectors utilize a VLF transmitter and receiver to detect the presence of a metal.
    They then discriminate between ferrous and non-ferrous materials based on the phase shift of the returned signal. This allows you to tell if the metal you are detecting is a rusty old nail or a gold coin as each type of metal will shift the phase of the bounced signal differently.
    Here is a basic overview:
    http://www.thomasathomas.com/Metal_detectors_work.htm
    0 michaelkellett over 10 years ago in reply to bobalexander
    But never mind -  the board you suggest is quite nice but based on an older STM32 processor which can't convert as fast as some of the more recent parts.
  • bobalexander
    0 bobalexander over 10 years ago in reply to michaelkellett
    Perhaps that is what the OP is wanting to detect though...
    Good call on the older STM32 - I didn't even think about it not being fast enough for processing signals in the kHz range.
    Yes, PI stands for Pulse Induction, that's the reason why I need fast measurement, see the curve in the figure:
