Ask an Expert Forum Hi and Reason for being here
  • Subscribers 307 subscribers
  • Views 608 views
  • present
  • christmas
See a helpful answer?
Hi! I am new to this forum, and there is a very specific reason I joined.
I am computer engineer, and this year, for Christmas, my brother is going to get a very special present from me. We usually give each other prank presents, but this year I want something special.
Here is what I have in mind:
a box, that will react when he shakes it or when it hears noises!
The reactions can be vibrations or voice responses.
For example, a simple shake will produce a complaining sound, a more vigorous shake will make the box vibrate and scream!
I have no idea where to start, so here is where your ideas and suggestions come in. I have been looking into the Arduino Uno, but I don't know if it will be enough for what I am thinking.
Last, but not least, last time I wrote a line of code was more than 10 years ago... so I will retrain myself image
Thanks!
arrobles
    dougw over 10 years ago +2
    Hi Alejandro, You can get an MP3 player module for less than $2 - it would just need a speaker and a battery. If you connect a vibration switch or even a tilt switch to the play button it will play the…
  • gadget.iom
    gadget.iom over 10 years ago +1
    Hello arrobles Welcome to the Element14 community. dougw has made an excellent suggestion, it really could be that simple. You could start with a project based on his suggestion, and then add an Arduino…
    0 dougw over 10 years ago
    Hi Alejandro,
    If you connect a vibration switch or even a tilt switch to the play button it will play the next recording on the TF (micro SD) card when shaken.
    No programming needed.
    You can store any strange audio or sequence of audio effects you want as MP3 files on the TF card.
    Doug
  • gadget.iom
    0 gadget.iom over 10 years ago
    Hello arrobles
    Welcome to the Element14 community. image
    You could start with a project based on his suggestion, and then add an Arduino and additional sensors incrementally as your confidence/experience builds. Don't be afraid to experiment, and as always the community will be available to help with any advice you need.
    Paul.
    If you  want more ideas on triggering and arduinos, check an earlier blog I made on the subject....
    Tis The Season For Arduino
    Doug
    0 Former Member over 10 years ago in reply to dougw
    This sounds like a great idea! I will look for the parts you mention!
    0 Former Member over 10 years ago in reply to gadget.iom
    I will give it a go this weekend (that is, if I find the parts image)
    I agree, it is an excellent idea!
    I read your post and that is what I was kind of expecting to do, but your idea of the MP3 module for the application I an thinking, sounds great.
    I will try the Arduino anyway image  I've always loved electronics and tinkering... just somehow I forgot I did.
