Ask an Expert Forum I am looking for substitute for a 9564gm mosfet.
  • Subscribers 339 subscribers
  • Views 1088 views
  • mosfet
  • p-channel
  • power
See a helpful answer?
My question is in the title.
    dougw over 10 years ago +2
    Check the datasheet for Fairchild FDS4685 to see if it is close enough. Doug
    0 dougw over 10 years ago
    Doug
  • clem57
    0 clem57 over 10 years ago
    For anyone not knowing about these https://www.youtube.com/watch?v=Te5YYVZiOKs
  • clem57
    P-CHANNEL ENHANCEMENT MODE POWER MOSFET
    TP2104 - P-Channel Enhancement Mode MOSFETs
    depends on your application of course.
  • jc2048
    0 jc2048 over 10 years ago
    SI4447 is a possible candidate.
    http://uk.farnell.com/vishay-siliconix/si4447ady-t1-ge3/mosfet-p-ch-w-d-40v-7-2a-so8/dp/2056685
    agree with you
    0 e14 Contributor over 10 years ago in reply to dougw
    Hello.
    I have an older chassis that rides on a trailer so it goes through shock and vibration. It only has one EM relay that activates when 120VAC is applied. It is a DPDT. The contacts only select 5VDC or Gnd as sense lines into a computer interface so current is not a big issue.
    Current relay is a plugin Potter & Brumfield KRP11AG120
    So, I'm looking to replace this relay with a SSR. 120VAC and DPDT for the two sense lines.
    Can you help me select a replacement? I'm sure back when this was designed they only used the EM relay because the used it to power up the DC supplies from the 120VAC main input.
    Thanks a lot.
    Mike
