Ask an Expert Forum 1080p@60 resolution on RIoTboard (I.Mx6solo) expansion header
  • Replies 7 replies
  • Subscribers 312 subscribers
  • Views 453 views
See a helpful answer?
Former Member over 9 years ago
I wanted to get 1080p@60 resolution from RIoTboard (I.Mx6solo) through the expansion header for CMOS display.I tried doing it by making changes in -
1) ~/riot/kernel_imx/arch/arm/mach-mx6/board-mx6dl_RIoTboard.c
2) ~/riot/kernel_imx/arch/arm/mach-mx6/board-mx6solo_RIoTboard.c
3) ~/riot/kernel_imx/drivers/video/mxc/mxc_lcdif.c
I managed to reach up to 30 frames per second but when I am trying to get more fps by changing the frequency and porch timing values display doesn't show up.
Is this possible to get 60 fps 1080p resolution using expansion header (parallel data) ? if possible how can i get it ?
Please help me out.
Abhishek Sharma
  • clem57
    clem57 over 9 years ago in reply to Former Member +1
    i.MX6S|i.MX 6Solo Processors|Multimedia|NXP Look at multimedia in chart showing 1080p@30fps. For SBCs, look for dual core GPU's Clem
  • mudz
    mudz over 9 years ago in reply to clem57 +1
    Haha I was two min late in replying the same
  • clem57
    0 clem57 over 9 years ago
    I am impressed you get 30 fps at 1080p. Most TV's this is considered top end unless you get newer 4K sets. Unfortunately the video core only allows a codec of 1080p@30 fps.
    Clem
    0 Former Member over 9 years ago in reply to clem57
    Thanks Clem Martins.
    You said that RIoTboard does not support 1080p@ 60 fps. Is this given in any of the data sheet or you are saying with your personal experience.
    And Is there any other board which can give 1080p@ 60 fps parallel data ?
    Abhishek Sharma
  • clem57
    0 clem57 over 9 years ago in reply to Former Member
    Clem
  • mudz
    0 mudz over 9 years ago in reply to Former Member
    Hi sharma.abhi2910
    Well It's always better to take a look at the datasheet first image
    Its already mentioned in that and on their webpage also: i.MX6S|i.MX 6Solo Processors|Multimedia|NXP .
    On the second question about And Is there any other board which can give 1080p@ 60 fps parallel data ?
    That depends! what kind of application you wish to use it in for, what features you like to have and at what cost?image
    mudz
  • mudz
    0 mudz over 9 years ago in reply to clem57
    Haha I was two min late in replying the same image
    Thanks clem57
