Ask an Expert Forum Need a 240V to 120V 100W transformer?
  • Replies 33 replies
  • Answers 3 answers
  • Subscribers 339 subscribers
  • Views 5394 views
See a helpful answer?
gizmo1990
gizmo1990 over 10 years ago
I'm looking for a transformer which I can use wto run an old American computer monitor here in the UK. The monitor has a label which says 120V and 85W MAX.
Could someone advise me if such a transformer is stocked here? Preferably one which is reasonably stand alone and does't require additional wiring?
Many thanks.
  • beacon_dave
    beacon_dave over 10 years ago in reply to shabaz +2 suggested
    Always difficult to tell without having it on the bench to actually measure. I seem to recall that over here at least electrical products drawing in excess of 500mA need to have their PF substantially…
    shabaz over 10 years ago in reply to gizmo1990 +1
    Hi Jim, That is a reasonable price, it is a hefty piece of metal. That is a typical size too, by nature of what it does and power rating. Like you, I'd be concerned about buying one from elsewhere like…
    shabaz over 10 years ago in reply to beacon_dave +1 suggested
    Hi, It's exactly that. Easier described as out of phase as you say, although in practice it happens due to non-sinusoidal waveforms too. The power the device (computer monitor in this case) consumes will…
  • gizmo1990
    0 gizmo1990 over 10 years ago in reply to beacon_dave
    Thanks again for the replies guys, I really appreciate your advice.
    Beacon Dave, that new transformer looks good and is within my budget, thanks for finding it. Regarding the parallel connection, that should be a fairly easy proceedure shouldn't it?
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to gizmo1990
    The data sheet sample application shows the secondary windings configuration of the transformer
    http://catalog.block-trafo.de/prodvardatasheet/393235-393306_EN
    but unfortunately they don't show actual connection scenarios. However there is some information on series/parallel connection of secondary windings at this site which should help you
    Multiple Winding Transformer and Multicoil Transformers
    Look for the heading 'Parallel Connected Secondary Transformer'
    They also have a section on the autotransformer which may be of interest to you and show why there is no isolation provided with that type of transformer.
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to D_Hersey
    Don Hersey wrote:
    Not W, but VA for some reason.  I think because the transformer is a passive device.
    Perhaps read up on real power, apparent power and power factor in AC circuits.
    As I understand it, generally W is used for calculations involving heat dissipation and consumer electrical tariffs whereas VA is used for calculating conductor sizes (transformer windings) and fuse ratings. Keep in mind that in AC circuits voltage and current are not always in phase which also makes W difficult to measure with the likes of a standard multimeter whereas VA is the product of the voltmeter and ammeter readings.
    Perhaps this subject is a contender for a Element14 bite-size tutorial ?
    0 shabaz over 10 years ago in reply to beacon_dave
    The power the device (computer monitor in this case) consumes will be given off as heat, and that is marked on the monitor in Watts.
    However, the apparent power could be larger. Plus there is a certain efficiency for the transformer (85% in this case I think - not looked
    again at the spec sheet).
    I've no idea what the power factor is (was), but I found this on google books:
    It would suggest that there is quite a lot of variance, but maybe 0.6 or 0.7 would be a good number to choose.
    So, that means 120-140VA but at 85% efficiency 140-160VA is more appropriate.
  • gizmo1990
    0 gizmo1990 over 10 years ago in reply to shabaz
    Hi Shabaz are you suggesting that the  TIM100TIM100 would not be sufficiently powerful to power the monitor Even though 85W is stated on the chassis Surely it should be fine
    Sorry if my question is in simplistic terms but I'm sure you guys have guessed this is going a little over my head!
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to shabaz
    I seem to recall that over here at least electrical products drawing in excess of 500mA need to have their PF substantially corrected. Not sure when that rule came in or if it was internationally adopted. However from previous tests with my budget power meter it appears to be true.
    Also the 85W referred to was specified as a maximum rating which probably means peak power draw at on switch-on and not continuous.
    There is the Block  TIM200TIM200 which is rated at 200VA but price jumps up again
    TIM200 - BLOCK - Isolation Transformer, Class II, 200 VA, 1 x 230V, 2 x 115V, 860 mA | Farnell element14
    0 shabaz over 10 years ago in reply to gizmo1990
    Hi Jim,
    As Dave says, the 85W might not be sustained. Also, the user docs for the monitor specify multiple screen sizes, but lists 85W as a general figure. A larger screen might be closer to 85W perhaps, a smaller one could be less, but I can't say for sure.
    It is all guesswork, this 85W is a number off a sheet of paper for a guideline to customers, it isn't a full detailed description - they possibly never expected a typical customer it to run on 240V and so they didn't provide more detail.
  • gizmo1990
    Damn, that would be annoying. image As Dave says, the price does jump a lot at 200W. Would seeing the manual for the monitor help? There's an online version here: http://www.wellsgardner.com/pdf/Service/K7000.pdf Does it include any info which might confirm one way or another? Also as it's 85W max, wouldn't that mean it doesn't need to be sustained?
    Hi Jim,
    The manual doesn't help (I'd already checked it out).
    I can't assume anything, the 85W is going to be some vague number is about all we know.
    No definitive answer on this one I'm afraid.
    We can take guesses, like that it may be a brief maximum.
    It is really down to you, what you feel comfortable with.
  • gizmo1990
    I feared that might be the case. I guess my only option is to try and find other users with experience of the monitor and see if they know concrete facts on the matter. And if that fails just drop the cash for the 200W version.
    I'd like to say that I really appreciate the help and advice I've received here. You guys have been really patient with my questions and I feel I've learnt a lot. Many thanks! And don't be surprised if you see me post again asking for help on connecting dual outputs in parallel. image
