Ask an Expert Forum Need a 240V to 120V 100W transformer?
  • Replies 33 replies
  • Answers 3 answers
  • Subscribers 339 subscribers
  • Views 5403 views
See a helpful answer?
gizmo1990
gizmo1990 over 10 years ago
I'm looking for a transformer which I can use wto run an old American computer monitor here in the UK. The monitor has a label which says 120V and 85W MAX.
Could someone advise me if such a transformer is stocked here? Preferably one which is reasonably stand alone and does't require additional wiring?
Many thanks.
  • beacon_dave
    beacon_dave over 10 years ago in reply to shabaz +2 suggested
    Always difficult to tell without having it on the bench to actually measure. I seem to recall that over here at least electrical products drawing in excess of 500mA need to have their PF substantially…
    shabaz over 10 years ago in reply to gizmo1990 +1
    Hi Jim, That is a reasonable price, it is a hefty piece of metal. That is a typical size too, by nature of what it does and power rating. Like you, I'd be concerned about buying one from elsewhere like…
    shabaz over 10 years ago in reply to beacon_dave +1 suggested
    Hi, It's exactly that. Easier described as out of phase as you say, although in practice it happens due to non-sinusoidal waveforms too. The power the device (computer monitor in this case) consumes will…
    0 shabaz over 10 years ago in reply to gizmo1990
    Hi Jim,
    No worries, we can address the connections question when you get to that.
    Sorry there wasn't a clear answer between which of the two to go for : ( I hope your project works out well. Is it an arcade machine?
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to gizmo1990
    If you can borrow a site transformer (or hire it <£10 from Jewsons) you could take an actual current measurement with a multimeter before deciding on purchasing a transformer for permanent use.
    You will also need the appropriate adapter cable though to convert from a 110v 16A commando plug though for the purpose of the test.
    You could also perhaps take the monitor to a local electrician and get them to measure the current for you.
    However, with these methods you will quickly have paid out the difference in cost between the two transformers.
    Another option might be to visit a local FabLab / Maker group who may have such test facilities that you could use.
    Just a quick question though - the manual mentions that the monitor can be furnished with an isolation transformer. I take it that you have checked that there isn't already a 1:1 isolation transformer in circuit ?
    The circuit diagram also shows a AC supply fuse rating of 1.5A so that gives an indication that the current will be significantly less than that.
  • D_Hersey
    0 D_Hersey over 10 years ago in reply to beacon_dave
    You will notice that properly labelled X-formers are rated in Volt-Amps, not Watts.  Not that it matters.
  • D_Hersey
    0 D_Hersey over 10 years ago in reply to shabaz
    The phase interpretation isn't too strained here if we introduce Fourier terms, maybe.
  • D_Hersey
    Calling them VA rather than Watts, upon reflection, generalizes the power output when driving a reactive load.  When I was a kid they made these things called 'factories' and sometimes they had large capacitor yards to compensate for their inductive (motor) loads.  In the case of a purely resistive load, like a stove, VA and Watts are equivalent.  Funny, I am not too far away from doing this same thing in the RF world, was taught about VA in HS, but the connection still didn't trigger for a few moments, gettin' old, forgetting some stuff, the recollections occur in fragments.
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to D_Hersey
    I believe that industrial factories are also 'metered' using VA and not W so makes sense for them to try and tame the inductive loads with the capacitor banks to get the power factor closer to 1, as it could substantially reduce energy costs for them.
  • D_Hersey
    Sorry, not really awake, thought I was posting in a thread about some guy's trailer.  I was awakened by a solicitor and in a daze.  NVM.
  • D_Hersey
    You are correct
    Just residential around here for ages
  • gizmo1990
    0 gizmo1990 over 10 years ago in reply to shabaz
    It is, these old monitors aren't well documented in some aspects but they are wonderful when they're working. At the moment though I'm not even sure if it works so the thought of paying £50+ to find out it doesn't would be annoying! I'm asking some other arcade enthusiasts about the monitors, maybe they'll come through with an answer.
  • gizmo1990
    0 gizmo1990 over 10 years ago in reply to beacon_dave
    Thanks for the suggestions Dave. Aye the trouble is I could very well end up spending the difference quite quickly. I'm posting in a monitor enthusiasts thread so perhaps someone there will know a definitive verdict?
    No sadly there's no transformer with the monitor. I aquired the monitor seperately and am putting it in my own casing. Afaik, originally whatever cabinet the monitor was in would have held its isolation transformer too.
