Ask an Expert Forum Need a 240V to 120V 100W transformer?
  • Replies 33 replies
  • Answers 3 answers
  • Subscribers 339 subscribers
  • Views 5432 views
See a helpful answer?
gizmo1990
gizmo1990 over 10 years ago
I'm looking for a transformer which I can use wto run an old American computer monitor here in the UK. The monitor has a label which says 120V and 85W MAX.
Could someone advise me if such a transformer is stocked here? Preferably one which is reasonably stand alone and does't require additional wiring?
Many thanks.
  • beacon_dave
    beacon_dave over 10 years ago in reply to shabaz +2 suggested
    Always difficult to tell without having it on the bench to actually measure. I seem to recall that over here at least electrical products drawing in excess of 500mA need to have their PF substantially…
    shabaz over 10 years ago in reply to gizmo1990 +1
    Hi Jim, That is a reasonable price, it is a hefty piece of metal. That is a typical size too, by nature of what it does and power rating. Like you, I'd be concerned about buying one from elsewhere like…
    shabaz over 10 years ago in reply to beacon_dave +1 suggested
    Hi, It's exactly that. Easier described as out of phase as you say, although in practice it happens due to non-sinusoidal waveforms too. The power the device (computer monitor in this case) consumes will…
  • rsc
    0 rsc over 10 years ago
    Be careful using US 120V devices on 220V.  Your monitor will most likely have a "grounded" chassis (connected to both the white and green wires of the "mains" plug)
    If you use an autotransformer, it will blow the fuse immediately.  Even if you use an isolation transformer, the chassis may be floating at 120V.
    We use these with field instruments:
    https://www.zoro.com/value-brand-step-updown-voltage-converter-300va-30c517/i/G5205742/?utm_term=R_PB60_Electrical&utm_s…
    Be safe.
    Scott
  • gizmo1990
    0 gizmo1990 over 10 years ago in reply to rsc
    Thanks for the warning Scott. I'm posting on monitor enthusiast forums to make sure that I've followed the correct safety procedures for the monitor. Hopefully I'll receive some hard information on the subject soon. And I'll be sure to post here if I have any queries too.
  • beacon_dave
    0 beacon_dave over 10 years ago in reply to rsc
    Ever had the lid off one ?
    That just looks like it contains a single transformer with 220v/110v taps on the primary and a either a dual 110v secondary connected in series or a centre tapped 220v secondary. No earth/ground provided on the 220v output.
