Ask an Expert Forum Relay help
  • Replies 19 replies
  • Answers 6 answers
  • Subscribers 318 subscribers
  • Views 2605 views
See a helpful answer?
Relay help
mark.yankowiak1@gmail.com
mark.yankowiak1@gmail.com over 9 years ago
I am trying to find a way to turn off a circuit with a red light, when another circuit with a green light is closed. When the green light circuit becomes open, the red light should turn back on.
Any help with this problem would be greatly appreciated.
-Thanks
    jw0752 over 9 years ago in reply to COMPACT +1
    Hi Compact, We have no semiconductors to protect and I am using a cuttler Hammer 400 Amp Switch so arcing won't be a problem. Based on what Mark gave us to work with we are both making a few assumptions…
    jw0752 over 9 years ago in reply to mark.yankowiak1@gmail.com +1 suggested
    Hi Mark, I drew this schematic very quickly and the RL is just a left over. If there were more than one relay they would be numbered RL1, RL2, etc. The SW2 switch can be replaced with a wire and SW1 can…
  • COMPACT
    COMPACT over 9 years ago in reply to COMPACT +1 suggested
    Modded for a single power source
    0 jw0752 over 9 years ago in reply to mark.yankowiak1@gmail.com
    Hi Mark,
    I drew this schematic very quickly and the RL is just a left over. If there were more than one relay they would be numbered RL1, RL2, etc. The SW2 switch can be replaced with a wire and SW1 can be just a washer touching two separated contacts.  Have Fun!
  • COMPACT
    0 COMPACT over 9 years ago in reply to COMPACT
  • mark.yankowiak1@gmail.com
    0 mark.yankowiak1@gmail.com over 9 years ago in reply to COMPACT
    Thanks COMPACT
    -Mark
    0 mcb1 over 9 years ago in reply to COMPACT
    I always like the "compactCAD" versions as you can see the evolution.
    Electronic drawings are fine but these are so much quicker.
  • COMPACT
    0 COMPACT over 9 years ago in reply to mcb1
    Here it is in reality.
    I used LEDs with current limiting resistors as the coloured lights.
  • geralds
    0 geralds over 9 years ago in reply to COMPACT
    you don't need a relay.
    Use just a double switch.
    If you use lamps you can use  an AC supply.
    If you use LEDs you have to use DC,
    or if you have AC then you needs anti parallel diodes to the LEDs.
    The right value of the R must be calculated for the LED current and supply voltage.
    The anti parallel diode can be 1N4007 (1N400x).
    Best Regards,
    Gerald
  • COMPACT
    0 COMPACT over 9 years ago in reply to geralds
    When using a two pole switch there is a transition zone where both the green and red circuits are either both on or off.
    The question is worded that the red circuit is monitoring the status of the green circuit.
    I have merely demonstrated a master monitoring configuration.
  • COMPACT
    If you want a changeover switch just use a SPDT (Single Pole Double Throw) switch.
  • geralds
    yes, this also happens with your SPDT. - between the two contacts the circuit
    will be interrupted for few ms, or sek, therefore the user as fast moves the switch lever.
    A parallel capacitor can help as a drop delay.
    Monitoring of the green circuit i also thought about, but we don't know specifically.
    He's question was a little bit vague. "one circuit;;; other circuit"
    - I've also drawn my schematic with two supplies and one with SPDT but I've not posted it because i thought the above may enough.
    Then the solution above with an relay or transistor may possible.
    Best Regards,
    Gerald
