Ask an Expert Forum doubt regarding  BQ24650EVM-639
  • Replies 13 replies
  • Answers 2 answers
  • Subscribers 339 subscribers
  • Views 2547 views
  • solar_cells
  • bq24650evm-639
See a helpful answer?
fabian_sl
fabian_sl over 8 years ago
I've been working with BQ24650EVM-639 and have successfully charged a battery with a couple of solar cells. I've even done the test suggested on the User's Guide and everything works as expected. My only doubt is regarding VSYS, I don't understand what is it's use. I would like to understand because on a project I'm working, I need to charge a battery AND at the same time, have 12V available for another load, and I'm not sure if VSYS could be my solution. If it's not, I still think it's important to understand what is VSYS for. Thanks in advance!
  • rsc
    rsc over 8 years ago +4 suggested
    From Figure 8. bq24650EVM Schematic pg17, VSYS = VIN - 1 diode drop (D1 - PDS1040) http://www.ti.com/lit/ug/sluu444a/sluu444a.pdf You should be able to use this for a general load < 8A if your power supply…
  • jc2048
    jc2048 over 8 years ago +2 verified
    VSYS is the output (system voltage). VOUT is the battery connection. It might have been better if they'd called VOUT 'VBAT'. As rsc says, VSYS is the diode-OR of the panel and the battery and is supplied…
  • jc2048
    jc2048 over 8 years ago in reply to fabian_sl +2 suggested
    The switchover occurs naturally, it doesn't need the charger chip to actively switch anything. When the panel is above the battery voltage it supplies the load and charges the battery. When the panel gets…
  • piyushy
    0 piyushy over 6 years ago in reply to piyushy
    Is it possible if Vsys can draw current directly from battery in this case?
    0 michaelkellett over 6 years ago in reply to piyushy
    Study the schematic, it tells you the max current for Vsys.
    Vsys is not regulated, it will be battery voltage or more.
  • piyushy
    0 piyushy over 6 years ago in reply to michaelkellett
    Ok.
    My load requires 40A, so should I then connect it directly to my battery like in the image below?
