Ask an Expert Forum PS4 Pro Power Supply Repair
  • Replies 15 replies
  • Answers 7 answers
  • Subscribers 346 subscribers
  • Views 18127 views
See a helpful answer?
Zehel
Zehel over 8 years ago
Yesterday while playing my PS4 Pro I heard a loud POP and my console was off. The lovely burnt electronic smell was in the air and I knew something had blown. My warranty is sadly up so I took apart my console looking for a popped cap anywhere. Turns out it was in the power supply. I already cleaned up the area but it looks like C31 was what blew. Does anyone know where I can either find a schematic so I can find out what that cap is, or know how I can identify the part?
Thank you!
    jw0752 over 8 years ago in reply to Zehel +6 suggested
    Hi Zehel, My eyes are not good enough to see a problem with the cap. Cap C29 near it looks to be the same and could be measured to give you a likely value for C31. If you can do this check C31 as well…
    mcb1 over 8 years ago +4 suggested
    Looking at the pictures, I doubt that C31 caused the burnt smell. As jw0752 said it's more likely the 'victim' of the original failure. It's more likely that one of the mosfet/transistors Q4-Q8? has gone…
    jw0752 over 8 years ago +3 suggested
    Hi Zehel, I am sorry to hear that you are having this problem. It has been my experience in situations like this that it is almost never the failure of the cap that is the root of the problem. Most of…
  • jonvellone
    0 jonvellone over 6 years ago in reply to abalancedepoch
    Hi, can someone help me with this?
    I have a powersupply n15-300p1a for a ps4 pro and have the primary transformer buzzing loudly on power on. Have changed and uprated all surrounding caps and coils but still it persists. It has written 37ppqm41002 hp0lf 18/15 b7h.
    0 jw0752 over 6 years ago in reply to jonvellone
    Hi Jonathan,
    If the power supply is working properly aside from the noise you may just have a noisy transformer. Sometimes they do not get sealed properly and the coil or some of the core laminations are loose and then they rattle. You could try shellac to better seal the transformer. If the power supply makes the noise even when not plugged into the ps4 then it is not the load that is causing the problem.
  • jonvellone
    0 jonvellone over 6 years ago in reply to jw0752
    Hi and thanks for your reply.
    The power supply seems to be operating normally, i can see a constant 12.1v to power the board.
    The transformer rattles on power on and increases on load . i tried sealing it with hot glue but it sounded the same.
    Do i have to dismantle it to apply shellac?
    Is there any schematics for this board? Its a chicony board
    Or do those numbers reflect any particular type of transformer so i can possible purchase a replacement.
    Thanks in advance
    The reason shellac might work where hot glue doesn't is that it can seep into cracks and crevasses. Not being able to see your transformer makes it difficult to comment. To enter pictures click on the icon in the line above that looks like this:
    and then follow the directions.
    If you put shellac on the transformer make sure that you let it dry well before you power it up. The most effective way to apply the shellac might be to submerge the transformer in it until it can soak into all the cracks. Otherwise brush it on and rely on capillary action to pull it where needed. I do not have any knowledge of the PS 4 power supply board but if you post some good picture I or one of the other guys could give you some insights. I am sure the numbers have some significance. Try googling them along with the name of the manufacturer and see what you get back. If you don't get anything it is probably because PS4 is having the parts made specifically for themselves and this will make it more difficult to find a replacement on the open market. I would look to see if I could find a power supply that is being sold as is or for parts. The most hardy component on the board is probably the transformer so that even if you buy a juck power supply the transformer is likely OK.
  • clee1
    0 clee1 over 6 years ago
    Does anyone know where to get T1 transformer? It seems like part number is MP-130I Delta AV-MP15135.
    My transformer wires are all broken from the leads.
