Ask an Expert Forum Miller Boost Circuit Board Assembly NO. 200841
  • +1 person also asked this people also asked this
  • Replies 60 replies
  • Answers 3 answers
  • Subscribers 344 subscribers
  • Views 21960 views
See a helpful answer?
lanuser
lanuser over 7 years ago
Hello everyone,
Let me tell you small story image
While back I have purchased dead  "MIller Dynasty 200DX"
After some repairs I have found damage to Boost Board that has internal ground planes  burnedout.
I have realisedthat i would need board replacement, however, board is dicontiniued and replacement board will cost me 2000 dollars if I found one.
After fiew hundret emails  and phone calls to different suppliers without even one ansfer I have desided  recreate board from scrach and make my own.
Fiew month later after reverse engineering pcb to schematic  and later on from schematic to PCB i have finally received new boards.
I have solder necesseryparts and run test on new assembled board, however, I have forgot take a maguments from resistor R86
Could some one be so kind and provide value number between pin 2 & 3 on R86?
Here is some pictures from original board and final my creation:
    jw0752 over 7 years ago +3
    Hi Alex, Reverse engineering a board of this size and complexity is a monumental task. Congratulations on what you have accomplished. Sorry I don't have the information you are looking for but your work…
  • lanuser
    lanuser over 7 years ago in reply to jw0752 +3 suggested
    Josh, First of thank you for your reply. Is to easy to reverse engineering this board, however, it is time consuming a speacially when team of one working on entire project. I'm planing some changes for…
  • A3JBNE
    A3JBNE over 4 years ago +2 verified
    The value of R86 as it says in the technical manual adjusts the limit for the line current, by default it is approximately 10 ohms. R86 makes a voltage divider with R99 adjusted from 0 to 7.5V approximately…
  • alvideo
    0 alvideo over 4 years ago in reply to mb443
    Work is still in design phase,  My idea is make aluminium oxide PCB, and screw pcb straight to radiator instead  original module. And after solder wires.
    Because there is a lof of space, i think to mount 3 phase bridge on radiator side like this
    https://www.amazon.in/Anbau-MDS100-16-3-Phase-Rectifier-MDS100A/dp/B07GLXB5HH
  • alvideo
    0 alvideo over 4 years ago in reply to guillermo
    guillermo said:
    I have doubts about how you can get there and impose a certain IGBT, not knowing the electrical parameters of the ORIGINAL.
    If You have understanding welding machines architecture and principles, this task is not very difficult. This project not first to  me. Before  i made my own pcb for Kemppi Minarc Evo 200 module, welder working over 2 years.
    So You need know module made on Mosfet or IGBT. In this case Miller use IGBT.
    Because DC bus is +840V, so IGBT needs for 1200V.
    Miller 200 Dynasty output amperage is 200, so one IGBT 40A  is enough.
    Next important parameter is input capacitance.... It's easy to measure on damaged module. So i don't see big seecrets.
    guillermo said:
    Will it be worth so much effort for an old machine?
    Of course not, but it's my hobby, for me it's interesting and challenge.
  • mb443
    0 mb443 over 4 years ago in reply to alvideo
    Guys, please let me know if anything I can help with, I do have an old power module, original. Anything need to be checked measured? I'd be glad to help.
  • lanuser
    0 lanuser over 4 years ago in reply to guillermo
    Idea is-------->>>>>>> Walk away from overpriced or obsolete SKIPP technology all together and not to pray on single company when their product is no longer available.
    However, Skipp  product line of IGBT modules are reliable and some units work for over 15 years.
    Reason why IGBT going bad:
    Answer: 90% LDO Fails on Booster Board sending across entire board 20-30 volts.
  • lanuser
    0 lanuser over 4 years ago in reply to alvideo
    Alvideo,
    I would disagree about your answer:
    Of course not,
    DX200
    It is reliable unit with really interesting analog design and not some digital 90% crap with fail rate of 60% in first couple years regardless of the brand.
  • guillermo
    0 guillermo over 4 years ago in reply to alvideo
    very insteresting...
  • lanuser
    0 lanuser over 4 years ago in reply to mb443
    Is your IGBT working condition?
    Do you have equipment to run some test?
    We need to test some electrical Characteristics of the IGBT.
    Or  tell us what type of IGBT test you are able to complete?
  • guillermo
    0 guillermo over 4 years ago in reply to lanuser
    how do you do it to replace the IGBT Q11 (IRG4PH50UD) when it fails if it is obsolete for years?
  • lanuser
    0 lanuser over 4 years ago in reply to lanuser
    Don't know about you, however, check ARROW I have purchased couple OEM.
    Since this part available IRG4PH50UD I have not looked for alternative, waste of time at this point.
    If I gonna search for alternative replacement for IRG4PH50UD there will be way better replacement part buy the time this part become 100% obsolete.
  • mb443
    Idea of aluminum PCB sounds ideal for this application!  And standalone bridge is also makes more sense.
