Ask an Expert Forum Miller Boost Circuit Board Assembly NO. 200841
  • +1 person also asked this people also asked this
  • Replies 60 replies
  • Answers 3 answers
  • Subscribers 344 subscribers
  • Views 21934 views
See a helpful answer?
lanuser
lanuser over 7 years ago
Hello everyone,
Let me tell you small story image
While back I have purchased dead  "MIller Dynasty 200DX"
After some repairs I have found damage to Boost Board that has internal ground planes  burnedout.
I have realisedthat i would need board replacement, however, board is dicontiniued and replacement board will cost me 2000 dollars if I found one.
After fiew hundret emails  and phone calls to different suppliers without even one ansfer I have desided  recreate board from scrach and make my own.
Fiew month later after reverse engineering pcb to schematic  and later on from schematic to PCB i have finally received new boards.
I have solder necesseryparts and run test on new assembled board, however, I have forgot take a maguments from resistor R86
Could some one be so kind and provide value number between pin 2 & 3 on R86?
Here is some pictures from original board and final my creation:
    jw0752 over 7 years ago +3
    Hi Alex, Reverse engineering a board of this size and complexity is a monumental task. Congratulations on what you have accomplished. Sorry I don't have the information you are looking for but your work…
  • lanuser
    lanuser over 7 years ago in reply to jw0752 +3 suggested
    Josh, First of thank you for your reply. Is to easy to reverse engineering this board, however, it is time consuming a speacially when team of one working on entire project. I'm planing some changes for…
  • A3JBNE
    A3JBNE over 4 years ago +2 verified
    The value of R86 as it says in the technical manual adjusts the limit for the line current, by default it is approximately 10 ohms. R86 makes a voltage divider with R99 adjusted from 0 to 7.5V approximately…
  • lanuser
    0 lanuser over 4 years ago in reply to guillermo
    Official Miller Authorized repair center " IF" they have one in stock.
    Get ready to spend approx. $1500 for the part ( that price 4 years ago )
    Now days because of Covid ,  no availability components in general  and if someone has one in stock I would say 2000k +  ( for that price you could get new alternative unit. )
    I got mine of supplier from China for $700
    There is also a problem: To obtain a IGBT component datasheet! This specific part has copy wright by Miller and Original manufacturer won't release it.
    Remember -> any DX 2000 series welder equipment has been release early of 2003 therefore no manufacture will continue make obsolete part for 19 years.
    I was trying to use new type of IGBT/FETS to replace this old garbage and wasn't able to get datasheet for pinout.
    There was other option to use bottom power distribution board that lays on top of IGBT... to reverse engineer... but I would need actual DX 2000 schematic from Miller. you know my chances of me getting actual datasheet? = 0
    Good luck with hunting.
  • guillermo
    0 guillermo over 4 years ago in reply to lanuser
    if I understand what you say.
    How was your experience with the Chinese copy of that IGBT bridge?
    or was it used?
    I have seen several ads on Aliexpress for this component and they cost what you say (U$ 700 approx.).
    my fear is that it's pirated junk, a painted case that doesn't work. In China there is a lot of Counterfeit electronics, for this we have the page UTSOURCE and MANYCHIPS famous for their scams.
    let me know how it went with the one you bought in china and the details of who sold it to you.
    Thank you.
  • lanuser
    From China used tested part. ( we have supplier in China and yes, in the past we received fake parts like everyone else )
    When you realize that you can't purchase original IGBT, regardless of the reasons only then you will start search for alternative IGBT replacement.
    DX200 It is outdated excellent unit with original price sticker $5K +
    Now because of single IGBT component entire welder  can be used for scrap.
    So.... instead of finding original IGBT I can build better one with new type IGBT FET and with higher amperage.
    IGBT contains:
    1. FETS
    2. DIODS
    3. Temperature resistor.
    However, without original IGBT datasheet or Miller DX200 series schematic I can't move forward.
  • mb443
    0 mb443 over 4 years ago in reply to lanuser
    if decided to reverse engineer the Power Module to replace w/ ext IGBTs then count me in if help w/ the project needed.
    As I've located it's a MiniSKiiP3 form factor with: 1200 V up to 150 A IGBTs
    some general info can be found at: docplayer.net/101233838-Miniskiip-power-modules.html
    But as custom made for Miller it may or may not include pfc (power factor correction) IGBT... and possibly isolated thermo resistor from the -DC
    I have a feeling it shouldn't be much different from standard NEC below except it seems has less than 6 IGBTs in package
  • lanuser
    0 lanuser over 4 years ago in reply to mb443
    I have one none working IGBT, however, in general I understand what and how inside of IGBT but I am not a component engineer.
    Most important is to pinout correctly oem IGBT.
  • alvideo
    0 alvideo over 4 years ago in reply to lanuser
    In market You can't find any similar IGBT module, don't waste time. Module is very specific, it has PFC and also active snubbers IGBT.
    I started make my own PCB on external IGBT, but not finished yet......
    https://drive.google.com/drive/folders/1MjTxi0BoNROP2rk7OWY194t6Mi4Pvw8m?usp=sharing
  • mb443
    0 mb443 over 4 years ago in reply to alvideo
    Wow! You actually got it done Jon! Have you got it to work or still in design phase? What was your plan, to bolt the new PCB right to radiator on the same spot as original power module or some other way externally? If so, then I guess  the rectifiers are on a separate module placed next to IGBTs?
  • guillermo
    0 guillermo over 4 years ago in reply to alvideo
    hmmm...
    The project looks interesting, but I have doubts about how you can get there and impose a certain IGBT, not knowing the electrical parameters of the ORIGINAL.
    Semikron does not provide this information because it signed an OEM contract with MILLER, that is, it is SECRET.
    I'm more open to finding a Semikron replacement by reverse engineering its components than buying overpriced counterfeit Chinese junk on Aliexpress.
    or in the worst case replace that module with IGBTS singles.
    The subject is very tedious and complex ...
    Will it be worth so much effort for an old machine?
    Wouldn't it be better to buy it used at a Miller disarmament store in AMERICA?
    Also, if you see any here, it makes the technical manual available, knowing that the patent has ALREADY EXPIRED.
    they don't even want to sell it.!!
    I really appreciate the help of some who contribute.
    I feel helpless knowing that there is no one who sells this module, not even Miller responds to my messages.
  • guillermo
    Can someone here buy this module in Germany and test the pinout with the original SKiiP 33 NEC 125 T2??
    www.tme.eu/.../SKIIP35NAB12T4V1.pdf
    www.semikron-shop.com/.../skiip-35nab12t4v1.html
    By nomenclature, the ORIGINAL is 50A/1200Vdc, I don't know the curves and so on, but according to the pre-CHECK power manual, the review of the PM1 module does have a three-phase bridge, a T° sensor, and 6 igbts with anti-parallel diodes.
    I therefore suspect that this Semikron 35NAB module could be an ideal candidate to replace the Miller original.
    What do you think of the pinout that needs to be modified ??
  • lanuser
    General pinout has been completed and (untested).
    PCB in the image incomplete ( no heat dissipation, however, idea is correct )
