Ask an Expert Forum Miller Boost Circuit Board Assembly NO. 200841
  • +1 person also asked this people also asked this
  • Replies 60 replies
  • Answers 3 answers
  • Subscribers 344 subscribers
  • Views 21969 views
See a helpful answer?
lanuser
lanuser over 7 years ago
Hello everyone,
Let me tell you small story image
While back I have purchased dead  "MIller Dynasty 200DX"
After some repairs I have found damage to Boost Board that has internal ground planes  burnedout.
I have realisedthat i would need board replacement, however, board is dicontiniued and replacement board will cost me 2000 dollars if I found one.
After fiew hundret emails  and phone calls to different suppliers without even one ansfer I have desided  recreate board from scrach and make my own.
Fiew month later after reverse engineering pcb to schematic  and later on from schematic to PCB i have finally received new boards.
I have solder necesseryparts and run test on new assembled board, however, I have forgot take a maguments from resistor R86
Could some one be so kind and provide value number between pin 2 & 3 on R86?
Here is some pictures from original board and final my creation:
    jw0752 over 7 years ago +3
    Hi Alex, Reverse engineering a board of this size and complexity is a monumental task. Congratulations on what you have accomplished. Sorry I don't have the information you are looking for but your work…
  • lanuser
    lanuser over 7 years ago in reply to jw0752 +3 suggested
    Josh, First of thank you for your reply. Is to easy to reverse engineering this board, however, it is time consuming a speacially when team of one working on entire project. I'm planing some changes for…
  • A3JBNE
    A3JBNE over 4 years ago +2 verified
    The value of R86 as it says in the technical manual adjusts the limit for the line current, by default it is approximately 10 ohms. R86 makes a voltage divider with R99 adjusted from 0 to 7.5V approximately…
  • mb443
    0 mb443 over 4 years ago in reply to lanuser
    As of pedal I have a schematic diagram, but never compared with original, not 100% sure if this fits DX200
  • lanuser
    0 lanuser over 4 years ago in reply to mb443
    Awesome,
    Thank you for the Miller "foot control" information!
  • serg200010
    0 serg200010 over 4 years ago in reply to alvideo
    Hello, I check the link it is not available, could please share you work?
  • lanuser
    0 lanuser over 4 years ago in reply to serg200010
    Can I ask specific what you are looking for in my work?
    If you asking for Gerber files or Schematic.... To avoid legal action from a Miller Corporation I will not share it on this forum.
    Thanks.
  • serg200010
    0 serg200010 over 4 years ago in reply to lanuser
    I am looking for a schematic but if it possible please share the gerbers as well. Is that going to be PM message?
    My story is, I have two boards first is working very well, second doesn't working at all, I have changed all microchips and transistors, Zenner and regular diodes. all resistors same as on the first board. but I got a brick board. I decided that I have trace burned some where but I don't have any schematic. It will be Great if you can share it. Appreciated for your help
  • serg200010
    Could please share schematic?
  • lanuser
    Save your self a time....
    Put light behind your board, you will see internal layer is burned out.
    You will have to fix internal layer GND.
    RC2 PIN #6 from the left and
    RC1 PIN#3 from the left
    Make sure board facing component side to you.
  • serg200010
    I have tried all variants, unfortunately without schematic diagram I can do more.
    if you can share a schematic diagram it will be Great.
    Thank you
  • Lat
    0 Lat over 2 years ago in reply to lanuser
    hi i need value the C;29
  • tlovie
    0 tlovie over 2 years ago
    Wow - this is an amazing accomplishment.  Can you provide the values of R6, R7, R8 - as I'm repairing one of these boards.  Many thanks.
