Ask an Expert Forum Doubt on RF connector and cables
  • Answers 3 answers
  • Subscribers 305 subscribers
  • Views 620 views
See a helpful answer?
shrins
shrins over 6 years ago
Hi, I am using the RF / Coaxial Connector CBBJR79CBBJR79 in my PCB design. I need a triaxial cable that is terminated at both ends with a three-slot male triaxial connector to connect from the PCB to the Keithley 6514 electrometer. The datasheet of the electrometer suggests to use 7078-TRX-57078-TRX-5 family of triaxial cables. My question is whether I can connect the  7078-TRX-57078-TRX-5 family of triaxial cables to the triaxial connector CBBJR79CBBJR79?
    shabaz over 6 years ago +1 suggested
    I don't know the answer, you might have to ask Keithley for the answer, but perhaps they expect/hope you to buy this bulkhead connector bulkhead connector instead. A bit more expensive though but still…
    michaelkellett over 6 years ago +1 suggested
    It looks OK - you can buy official and much cheaper un-official tri-axial cables from RS:664-6441 You could buy one and check that it fits both the Keithly and your connector. You need to watch out because…
    0 shabaz over 6 years ago
    I don't know the answer, you might have to ask Keithley for the answer, but perhaps they expect/hope you to buy this bulkhead connectorbulkhead connector instead. A bit more expensive though but still in the same ballpark as the one you're using on your PCB. The next question is what cable to use with that! You might need to talk to the manufacturer.
    0 michaelkellett over 6 years ago
    You need to watch out because there are 3 lug and 2 lug tri-axial BNC connectors which won't mate - Keithley use 3 lug.
  • shrins
    0 shrins over 6 years ago in reply to shabaz
    I have to use that connector CBBJR79 in my PCB. I am using Keithley 6514 electrometer for my measurements.  Since I couldn't find the the dimensions of the https://www.element14.com/community/view-product.jspa?fsku=2077466&nsku=97B3693&COM=noscript7078-TRX-5 family triax cables, I don't know whether it will be compatible with  CBBJR79.. Any suggestions on how can I get more information on this?
  • shrins
    0 shrins over 6 years ago in reply to michaelkellett
    Michael, I have to use CBBJR79 in my PCB and Keithley 6514 electrometer for the current measurements. I was not able to find the dimensions of the 7078-TRX-5 family triax cables, I don't know whether it will be compatible with  CBBJR79.. Any suggestions on how can I get more information on this?
    Correct Answer
    0 michaelkellett over 6 years ago in reply to shrins
    There is a Keithley data sheet for the cable but it has no dimensions or part numbers for the connectors they use !
    All I can suggest is that you actually measure the CBBJR79 and the connector on the instrument and compare the two.
    If they are the same the standard cable will work.
