Ask an Expert Forum Li-ion charger function
  • Subscribers 315 subscribers
  • Views 433 views
  • controller
  • li_ion
  • charger
See a helpful answer?
grahamedriver
grahamedriver over 13 years ago
Hi people
I have just bought this item http://www.ebay.co.uk/itm/251033573807 (not arrived yet) and I was looking for some advice, always a good ploy, especially if it avoids having cells catch fire.....
The spec says
Input volt (between B+ / B- )
VSS-0.3~VSS+26
V
but what does that mean? As far as I can see the voltage between B+ / B- is the battery voltage (say 4x3V7).
Also how do I determine the charge voltage? Do I need to (except to ensure it is sufficient and sensible)?
I hope this is all obvious to someone who knows.
I have messsaged the supplier but no answer yet.
Thank you
    0 Former Member over 13 years ago
    From what I can tell they mislabelled things. P- and P+ should be power input into the circuit with everything between B- and B+ being output of the charger. Unless this is designed to take input from 4 batteries to charge another circuit, but I doubt that. But pay attention to the operating voltage which is between 2V and 24V So anything between that will charge the batteries. But I recommend inputting more then 15V if you will be using 4x 3.7V Li-ion batteries.
  • grahamedriver
    0 grahamedriver over 13 years ago in reply to Former Member
    Hi Micheal
    Thanks for that
    I did wonder whether they meant P- and P+.....maybe.  I have just received an answer from tchwarehouse-au
    "input voltage is 16.8v to 18v"
    How this comes from the data I don't know but I guess that is to say a bit more than 4x3V7, as I suspected and you suggested. It seems to me unlikely that the circuit will charge with anything lower than the battery voltage (I see no inductors), still stranger things....
    So I am still unclear what is meant by "input volt" and "operating voltage".  AFAIK in discharge mode the output voltage can range only from a little below, to a but more below, the combined nominal voltage of the 4 cells in series.
    Maybe I'll know more  when I get to play with it.
    0 Former Member over 13 years ago in reply to grahamedriver
    I'd be interested in what you find out.
