I am very new to electronics and as such, I have no clue what most of the components are actually called. I want a tactile switch that breaks the connection when you press it, and allows the connection when it is not pressed. I have no idea what this is called though, and may have passed right by it searching because of this.
Can anybody tell me what it is called, so I can search and buy a couple.
This is for a "just for fun" project. Basically I have an LED that I want to wire up. I have a regular tac switch in the circuit, so that when you press it, the LED lights up as long as the switch is pressed. I would like to add a slider switch so that it goes to another leg of the circuit where the LED is always on, and you press another tac switch to momentarily break the connection and turn the LED off. I have everything I need except this second tac switch, because I don't know what it's called. Thanks for any help.
