Ask an Expert Forum Vu meter
  • Subscribers 316 subscribers
  • Views 566 views
  • frontpage
See a helpful answer?
Vu meter
magnus2112
magnus2112 over 11 years ago
So, i just had an idea to make a vu meter.
I searched a bit online, and found out that a lot of people are using the LM3915 chip.
But my question is how do i make the LM3915 react to a spesific hertz?
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    A simple band pass filter then fed through a diode to an RC circuit. The average DC level will represent the amplitude of the band your filter is set to
    You can do the whole thing in analogue with a bar graph display or you can feed the rc output to an ADC and have the micro-controller do the display
    Peter
  • mudz
    0 mudz over 11 years ago
    Greetings,
    Band pass Filter method will do the job.
    Do you only wish to make a VU meter or Just want to make led's dance with music?
    Here are two videos, I made this thing for a friend he asked me to make led's dance according to the music. If you wish to make led's dance, you will need condenser mic, capacitors, few resistors, transistor etc.
    Take a look:
    These LED's was on a breadboard, it was a testing circuit, the final circuit was on a PCB. Also, you can make different color LED's to respond to different sound levels. Advantage of these units: as their input is a condenser mic so they can be installed away from signal or no input signal required. They works on sound coming out of the speakers image.
    Good Luck image
