Ask an Expert Forum Advice wanted for reading from PC <- TENMA 72-10410  DIGITAL MULTIMETER with RS232
  • Subscribers 310 subscribers
  • Views 1609 views
  • rs-232
  • multimeters
  • digital_multimeter
  • rs232
  • multimeter
  • ftdi
See a helpful answer?
I am looking for a multimeter whose measurements can be sent to a PC. Someone suggested the following multimeter from Farnell: 72-10410 - TENMA - DIGITAL MULTIMETER, HANDHELD, 3 3/4DIGIT | Farnell element14 België.
I want to connect the multimeter to my Raspberry PI's usb, for which I will need a serial to USB converter cable (RS232). I am quite new with multimeters and electronics as a whole, can someone verify if I will be able to use the following cable with this multimeter? http://be.farnell.com/ftdi/ttl-232r-3v3/cable-usb-to-ttl-level-serial/dp/1329311
If someone knows a better method to get multimeter readings on the Pi: suggestions are always welcome!
Best regards
    mcb1 over 11 years ago +1
    I brought a Tenma meter that does logging, but I'm away from home and can;t find the reference number. This one will do what you want. Tenma 72-7745 Tenma 72-7745 However I can't find the cable number…
  • javagoza
    javagoza over 6 years ago +1
    Hi, Look at this link, Ithink it can help you. https://www.swharden.com/wp/2016-08-24-tenma-multimeter-serial-hack/
    0 mcb1 over 11 years ago
    Tenma 72-7745Tenma 72-7745
    However I can't find the cable number, which clips into the back.
    There is a writeup here.
    http://masteringelectronicsdesign.com/tenma-72-7745-multimeter-review/
    edit
    It was an Agilent that I brought
    Agilent U1241BAgilent U1241B
    IR to USB cable
    IR to USB leadIR to USB lead
  • javagoza
    0 javagoza over 6 years ago
