Ask an Expert Forum Which surface mount resistor is this?
  • Replies 19 replies
  • Answers 2 answers
  • Subscribers 342 subscribers
  • Views 3426 views
  • smr
See a helpful answer?
hafcanadian
hafcanadian over 11 years ago
I can't find a local source for a SMR that somehow got knocked off an outdoor solar lantern's PCB while I was trying to refurbish it.  Thankfully I had another device and could look to see which one it was.  But I can't figure out what to order online.  I took both devices to a well-known local electronics store, but the tech at the counter looked at the intact one with a magnifying glass but couldn't tell me which SMR I needed either.
The numbers on it are either 1101 or 1011.  I can't tell which direction to read it, and am no electronics expert by any means.  Attached are photos of the intact and functional PCB.  The SMR I need another of is in position R3.  Can anyone advise me which one of many offered by Element 14's catalog is correct?
Joel
    mcb1 over 11 years ago in reply to hafcanadian +2
    I take it that it doesn't matter in this application what the resistor's specifications are, such as milliwatts, voltage, case style? In this application probably not... EXCEPT the case style needs…
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1 verified
    It is either a 1.1k or a 1.01k and I would think either would work in your circuit Regards
    mcb1 over 11 years ago in reply to Robert Peter Oakes +1 suggested
    You should also be able to measure it. If you really wanted, a small cut on the track below or right of the silkscreen R3 would isolate it. The cut is easy to fix with some solder. Mark
    0 Robert Peter Oakes over 11 years ago in reply to hafcanadian
    Im hoping you meant that you ordered a 1.1Kohm, not a 1.1ohm or your now talking about a different resistor than earlier image otherwise your in for another 6$ SMD resistor image
    0 mcb1 over 11 years ago in reply to hafcanadian
    the SMD was 8 cents, the shipping $6
    I tend to get 10 - 25 of them as eventually one day you will need them.
    I also tend to get other values at the same time ...
    Keep them in a sealed plastic bag ... they'll be fine for years to come.
  • hafcanadian
    0 hafcanadian over 11 years ago in reply to Robert Peter Oakes
    Yup.  My bad.  I meant it is 1100 ohms.
    OK, lucky you image, for that price I would have ordered a few other ones to play with as you have to pay the 6$ anyway... Ah well
  • hafcanadian
    0 hafcanadian over 11 years ago in reply to mcb1
    I thought about getting more, but I look at any one board I come across and I see all different numbers on the resistors.  On Amazon, and maybe on Newark (I didn't look), they seem to be selling packs of assorted SMD's.  But there are so many, I didn't have time to peruse them all trying to find the optimal mix of potential future needs.
    Joel
    hafcanadian
    Joel
    There are a standard range of values E6 to E192.
    http://www.logwell.com/tech/components/resistor_values.html
    Even if you just went for the E12 values, you'd be covered for most things.
    so 10, 12, 15, 18, 22, 27ohm, etc
    100, 120, 150ohm, etc
    1.0k, 1.2k, 1.5k etc
    10k, 12k, 15k, etc
    100k, 120k  ..... you get the picture
    For most microcontroller work a 220ohm in series with LEDs, 1K, 2k2, 4k7, 10k and maybe 470K or 1M should just about do it.
    If you are designing the boards, then 0805 is a good size to handle, but other repairs might require smaller sizes.
    (I have some I inherited that have no marking and look like big sand flakes.... I think they are 0201)
  • hafcanadian
    Well, I'm not building devices, but rather just trying to fix household items that go haywire, often due to either too much heating/cooling cycles (micro-cracked solder points) or corrosion on outside solar lights, etc.  On Amazon they offer many kits of SMD resistors.  In my life I may need 5 or 10, not thousands.  Ditto for other PCB components.
    http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=smd%20resistor#/ref=sr_nr_n_6?fst=as%3Aoff&rh=n%3A16310091%2Cn%3A306804011%2Ck%3Asmd+assortment&keywords=smd+assortment&ie=UTF8&qid=1431223286&rnid=16310161
    Can anyone suggest a kit that a retailer offers that includes an assortment of more common components of all types?  Something like a few capacitors, standard resistors, diodes, surface mount resistors, board-mount LED's, different types and sizes of switches, etc. that a homeowner without access to drawers of components might need from time to time.  From what I've seen, the only things that really corrode out or fail are switches or LED's, or wires break at solder points and solder points develop micro-cracks from hot/cold cycling or impact.  If I knew where the original SMD for position R3 in this case got knocked off at, I could solder it back on the board and it would probably work.
    But a kit full of various types and sizes of common board components would be handy.
    Joel
    Adafruit do books for SMD resistors
    0805  http://www.adafruit.com/products/441
    0603  http://www.adafruit.com/products/442
    Terry King does a good range of varying parts
    http://yourduino.com/sunshop2/index.php?l=product_list&c=36
    But if you do want quantities of other items, SeeedStudio have the OPL catalogue.
    http://www.seeedstudio.com/depot/OPLopen-parts-library-catalog-c-136_138/?ref=side
    0 michaelkellett over 11 years ago in reply to hafcanadian
    Your best bet is to collect dead boards, they'll be free and you can reclaim passives quite easily.
    I keep E24 resistors in 0402, 0603 and through hole from 10R -> 1M but it's a few hundred £ to start off. I only buy caps and inductors for jobs - just too many variants to keep a complete set.
