I was hoping for some insight into a project I am working on. I have a 220v dust collector for my CNC machine, it uses a contactor to start and stop the motor load. The contactor also has a remote controller that allow for remote power control. I need to control the dust system from my CNC controller which in turn has a latching relay output (controlled by my gcode).
I need help with a circuit that can pulse (one shot) when the rising edge of the CNC relay controller pin to activate the dust system, and another pulse to trigger the motor contactor off when the CNC relay output goes low
The startup circuit seems easy enough with 555 timer that pulses when the relay latches on, I am having difficulty figuring out how to send a pulse when the circuit detects the relay load is turned off.
Thanks all in advance!
Alan Jurim
