Ask an Expert Forum Best way to disconnect a SOIC-8 pin?
  • Replies 22 replies
  • Subscribers 337 subscribers
  • Views 7916 views
See a helpful answer?
Andrew J
Andrew J over 3 years ago
I've accidentally connected a pin to GND and it should have been left unconnected.  It's pin 5 of an 8-pin SOIC so reasonably accessible but what would be the best way to actually disconnect it without stressing other pins?  Note that the track that connects it to GND is very short and actually under the IC so isn't accessible.  I don't really want to de-solder the chip so all I can think of is to try and wick up the solder from that pad and then gently bend the pin up.  I've found that trying to wick it up is quite difficult because there's always some that remains under the pin.
  • scottiebabe
    scottiebabe over 3 years ago +6
    Go big! lol
  • baldengineer
    baldengineer over 3 years ago +4 verified
    I would heat up the pin, lift it, and then wick any solder left making a connection. In fact, you may find adding some solder first helps to make lifting it easier.
    michaelkellett over 3 years ago +3
    I would cut the pin, I do have a nice pair of rather expensive micro cutters for this purpose. Works well on SOIC, less good on 0.5mm pitch pins. You can (with care) use a scalpel with a nice new blade…
    0 e14 Contributor over 3 years ago
    [deleted]
  • Gough Lui
    0 Gough Lui over 3 years ago in reply to e14 Contributor
    Spam reported.
