Ask an Expert Forum Need some explanations
  • Subscribers 324 subscribers
  • Views 936 views
See a helpful answer?
soananaa
soananaa over 3 years ago
Hi, can we use part #HCPL2631SDM as replacement for HCPL2631SD ?
and can you please explain impact due to variation in output current ?
Best, Lilian
telegram sexe
    shabaz over 3 years ago
    Some engineer should be looking at your circuit to make this decision, and some testing would be required. I don't think it is safe to assume it will work, although there's a very good chance it will. No-one knows if your circuit is operating the device at the edge of margins for instance, and there are small differences which might not affect anything at all, but it is impossible for anyone to tell, unless they examined your circuit, and ran tests.
    dougw over 3 years ago
    Can you post the portion of the datasheets that needs explanation? The M parts seem to have higher transient protection but are otherwise similar. What (ESD) environment are these intended to work in?.
  • taifur
    taifur over 3 years ago
    There are some parameters differences between these two ICs. For example the M variant has more insulation voltage than other (5kV vs 2.5kV). Even M variant has faster response I guess. As M variant has better response I think you can replace HCPL2631SD with HCPL2631SDM.
    Please note this is not an expert opinion.
