Ask an Expert Forum Looking for a can-bridge 2 channels.
  • Subscribers 324 subscribers
  • Views 1240 views
See a helpful answer?
felipeab79
felipeab79 over 2 years ago
Hi, I am looking for a can-bridge 2 channels plus extra i/o port that I could program to filter can messages between the can-bus port and trigger message when received a digital signal on extra port.
I found one here, https://www.google.com/amp/s/www.hackster.io/news/emile-nijssen-s-open-source-can-bridge-makes-automotive-man-in-the-middle-a-cinch-b4dfeb952b04.amp, but seems that is not available from provider. Would be great to have one like that to test a function on forklifts.
Waiting for your ideas and colaboration, maybe you have capability to manufacture and support me.
thanks in advance
Felipe
    michaelkellett over 2 years ago +4
    What to recommend depends a lot on your software skills. A long time ago (25 years) I designed a similar device which connected a rear passenger air con to the main vehicle air con in a famous make of…
    Jan Cumps over 2 years ago +3
    Would a microcontroller with 2 CAN peripherals do the job? They also have GPIOs. you'd need to add the CAN tranceiver ICs.
  • charlieo21
    charlieo21 over 2 years ago +2
    It's open source, you can make your own version
  • charlieo21
    A long time ago (25 years) I designed a similar device which connected a rear passenger air con to the main vehicle air con  in a famous make of luxury car to limo conversion. It had two can ports, a serial port and a diagnostic port.
    The hardware for such things is pretty simple but you end up writing all you own code and need a good understanding of CAN.
    I think you can do it with off the shelf stuff from Vector which will work fine but be quite expensive.
    Are you looking for a plug an go solution and is it just a one off for testing ?
    Are you able to write the code at processor register level in C (you will probably need to do so to minimise delay through the bridge.)
    Are there any safety implications ?
    Jan Cumps over 2 years ago in reply to michaelkellett
    When you have the time, I'd be interested to learn how you handled this.
    michaelkellett over 2 years ago in reply to Jan Cumps
    Long time ago so I have no pictures and no design files but I do have ALL my notebooks since about 1975.
    I think this design was about 1998 - I'll do some digging when I get  a moment and start a new thread or maybe a blog.
    That may be worth yet another blog <3
