Ask an Expert Forum Rms converter to match HP3400A?
  • Replies 72 replies
  • Subscribers 335 subscribers
  • Views 12282 views
See a helpful answer?
ggabe
ggabe over 3 years ago
What is your suggestion to match the specs of the HP3400A AC millivoltmeter’s rms converter with analog parts available today? I’m drawing a line to exclude AD conversion and digital rms calculation. So it stays analog.
Below is the spec sheet:
  • ggabe
    ggabe over 3 years ago in reply to phoenixcomm +4
    My motivation is “restoration”. This is the only analog instrument I have. I like the retro vibe of the mirrored gauge. Three different rms converters in my parts box already, time to make them work all…
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe +4
  • scottiebabe
    scottiebabe over 3 years ago in reply to phoenixcomm +4
  • phoenixcomm
    phoenixcomm over 3 years ago in reply to phoenixcomm
     ggabe  BTW what died.. I'm not an analog type. But I just had a peek at the schematics and it doesn't look too hard to repair. Do you know what part(s) died??
  • ggabe
    The thermal converters blown out. I see many repairs/replacements.
  • anniel747
    anniel747 over 3 years ago in reply to phoenixcomm
    A 113 goes to 10MHz?
  • ggabe
    My motivation is “restoration”. This is the only analog instrument I have. I like the retro vibe of the mirrored gauge. Three different rms converters in my parts box already, time to make them work all together. Spicing it up to meet or exceed the 10MHz 5% rms measurement accuracy. Which can easily met by any of today's oscilloscopes, just that I like analog and want to push analog to its limits.
    michaelkellett over 3 years ago in reply to ggabe
    The meter movements on the 4xx series of HP instruments are really nice (so long as the paint hasn't flaked.)
    I'm not sure that I'm up to the challenge of attempting to replicate the external power sensor for my 435s but it would be nicer than altering the insides.
  • phoenixcomm
    phoenixcomm over 3 years ago in reply to ggabe
    do you mean TC401 & TC402 on page 47?? if so part numbers for both are D853-0003 if so I Keysite looking into it.
  • scottiebabe
  • scottiebabe
  • ggabe
    ggabe over 3 years ago in reply to scottiebabe
    Two more lesser known facts about the 3400A:
    1. The input stage uses a miniature nuvistor tube. Seems reliable JFET solution was not available back in the days, when it was new in 1964.
    2. Chopper amplifier used CdS photo resistors + neon strobe lights to implement “fast” analog switches.
    The follow-on model, 3400B got a JFET replacement of the nuvistor, among many other modernization, like chopper stabilized opamp, and the bandwidth went up to 15MHz. Thermocouples stayed.
  • phoenixcomm
     ggabe Keysight just got back to me.. Im copying the pdf into this:
     KeysightCare Case # 01362418, 3400A Questions [ref:_00D1aawb5._5005a2ZlXvL:ref]
    Good Afternoon Cris and thanks for Contacting Keysight!
    I left you a vm in the morning and now following up with an email as well.
    Not sure if we got the model number wrong but I had to dig deep to find this really really old 3400A. :)
    Unfortunately we do not have a direct replacement but for RMS and thermocouple measurements, please check if our 34465A or 34470A (data sheet attached) meet your needs. (( its just their new test equipment
    Below are also the compatible t/c offerings to the 34465A/70A:
    34307A Thermocouple Kit (10 J-type, bare wire termination)
    U1180A Thermocouple (J and K-Type) and Temperature Probe Adapter
    U1181A Immersion Temperature Probe (K-Type Thermocouple)
    U1182A Industrial Surface Temperature Probe (K-Type Thermocouple)
    U1183A Air Temperature Probe (K-Type Thermocouple)
    U1184A Temperature Probe Adapter (Thermocouple NOT included)
    U1185A Thermocouple (J-Type) and Temperature Probe Adapter
    U1186A Thermocouple (K-Type) and Temperature Probe Adapter
    U1188A Thermocouple (K-Type) with built-in Adapter
