Ask an Expert Forum Rms converter to match HP3400A?
  • Replies 72 replies
  • Subscribers 335 subscribers
  • Views 12355 views
See a helpful answer?
ggabe
ggabe over 3 years ago
What is your suggestion to match the specs of the HP3400A AC millivoltmeter’s rms converter with analog parts available today? I’m drawing a line to exclude AD conversion and digital rms calculation. So it stays analog.
Below is the spec sheet:
  • ggabe
    ggabe over 3 years ago in reply to phoenixcomm +4
    My motivation is “restoration”. This is the only analog instrument I have. I like the retro vibe of the mirrored gauge. Three different rms converters in my parts box already, time to make them work all…
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe +4
  • scottiebabe
    scottiebabe over 3 years ago in reply to phoenixcomm +4
    Jan Cumps over 3 years ago in reply to anniel747
    There's a school of reworkers (not surprisingly headed by Louis Rossmann who sells flux Slight smile) that say you can never use enough flux. They call it "a decent amount of flux" ©
  • anniel747
    anniel747 over 3 years ago in reply to Jan Cumps
    Yeah, PCB flooding.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps
    Jan Cumps over 3 years ago in reply to scottiebabe
    Parts should come with this label:
    michaelkellett over 3 years ago in reply to scottiebabe
    I reckon the no-name EVBs run at about 10% of the price of the manufacturer branded parts. The thick gooey flux seems to be a feature. So far I've had 100% success with such boards - I'm happy to run the risk since it means I can play with a lot more stuff than otherwise. If it were a project for a customer I would (probably) buy the real thing.
    I've just received two different boards for the AD8367. The flux looks as if the board had been dipped in honey, I've cleaned one up but not got round to testing yet.
    I'll start a new blog about it when I do.
  • scottiebabe
    scottiebabe over 3 years ago in reply to michaelkellett
    I have to confess that I got the idea of using the part from
    community.element14.com/.../ggabe
  • anniel747
    www.eletimes.com/the-growing-market-of-counterfeit-electronic-components-and-its-repercussions
  • ggabe
    ggabe over 3 years ago in reply to anniel747
    In the article “Manufacturers should opt for blockchain technology to locate the components as separate blocks in the chain. This way they can verify precisely where the parts came from and when they arrived in the supply chain.”
    However, it is easier said than done. The author’s mention of this alongside visual inspection on the same page undermines the credibility of the article.
    michaelkellett over 3 years ago in reply to ggabe
    I once read that when X tells you that the answer to Y is Blockchain, then the only thing you learn is that X knows nothing about Y or Blockchain.
    More seriously - I'm happy to buy parts of uncertain origin to play with, I wouldn't buy them for serious work let alone safety critical stuff.
    The little Eval boards from China are not obviously fake or counterfeit. The chips on them work fine (although they might be second hand). The boards I've bought recently are not clones but new designs (although based on the app notes which is perfectly OK).
    They provide a service to the greater good by applying price pressure to the major players, and if they use second hand parts that helps the planet too.
    There are certainly fake parts around which don't really work at all or are dangerous - and I wouldn't knowingly buy them or support their production.
