Ask an Expert Forum Replace Transformer for electric gate
  • Subscribers 325 subscribers
  • Views 1516 views
See a helpful answer?
Benny33
Benny33 over 2 years ago
I need a replacement for my electric gate.  Can you advise if is will fit - VPT24-4170 "au.element14.com/triad-magnetics/vpt24-4170/transformer-toroidal-2-x-12v-100va/dp/1785741"?
WEBB PT-100VA
    shabaz over 2 years ago +2
    Hi, It might be OK from an output point of view, but I have no idea if it is OK from a safety point of view, since there are standards and it's complex, only the manufacturer can advise. If you decide…
    shabaz over 2 years ago in reply to shabaz +1
    (Can't edit) Also, the primary wires need to be connected in series on that transformer, again documented in the datasheet how to do that.
    It might be OK from an output point of view, but I have no idea if it is OK from a safety point of view, since there are standards and it's complex, only the manufacturer can advise. If you decide to use it, then you'll need to follow the datasheet when you connect the two secondary windings together, it mentions in there what color wires to join.
    Since I don't know your experience and you have not mentioned it, and especially because you asked the question which an engineer would already know, I have to state, make sure it is faulty first before you replace it (transformers don't often fail, although some will have an internal safety cut-out that could render it unusable, but then there's likely to be a fault elsewhere too, to have caused the cut-out to occur), and you should only replace it if you know what you're doing.
    (Can't edit)
  • cstanton
    cstanton over 2 years ago
    Converted to forum thread from blog post.
    Jan Cumps over 2 years ago in reply to shabaz
    I checked the Webb website. They are generic (and come in 3 sizes)
    The replacement above allows that  primary is in series, and also that secondary is used in parallel. And its 100.7 VA.
    Frequency matches. I'd say it's a fit
