Ask an Expert Forum The best transistor replacement
  • Replies 22 replies
  • Subscribers 335 subscribers
  • Views 6656 views
  • Replacement transistor grundig ts1000
See a helpful answer?
b139b
b139b over 3 years ago
Hello everyone. Hope you all are doing well Thumbsup
I need some smart input from you... I am looking for some replacement transistors for my old tape recorder. The recorder sounds like a thunderstorm, so I think one transistor is bad. Since those transistors (BC330C, BC237B, BC238B) not are available anymore, I am looking for replacements.
In this case, since the design already is given, is "typical hfe" the parameter witch is most important to match with the original transistor? - To keep the same amplification steps.
All maximum-voltages must of course to be the same or higher to the original.
I have some BC550C with hfe=420-800. Is it correct to think that the typical hfe for the BC550C is in the middle of this values =610 ? Too much amplification in my case?
Any input is appreciated Blush
Christian
  • baldengineer
    baldengineer over 3 years ago +3
    b139b said: The recorder sounds like a thunderstorm, so I think one transistor is bad Have you already replaced the electrolytic capacitors? They are far more likely to have gone bad.
  • Gough Lui
    Gough Lui over 3 years ago in reply to baldengineer +3
    That and potentiometers ... *crackle crackle - Gough
    shabaz over 3 years ago +2
    Hi, The BC550 is likely fine for all of these NPN transistors, since the actual transistor gain doesn't matter usually (because the circuit will control the actual gain). The BC550 is a very decent substitute…
  • b139b
    b139b over 3 years ago in reply to ggabe
    Thank you for your reply! C25/C26 are you new. I have not checked it, but since the thunder is only in the right channel, the voltage would not be equal at R77/R78. I am on holyday until next week, so I check when I am home again
  • b139b
    b139b over 3 years ago in reply to shabaz
    Thanks. I have a scope, and the phonic can be a scope too. I have switched the recorder to manual.
