Ask an Expert Forum Vacuum tubes (valves)
  • Replies 11 replies
  • Subscribers 334 subscribers
  • Views 2361 views
See a helpful answer?
Dimebaggins
Dimebaggins over 3 years ago
I would like to build audio amplifiers. I assume that a vt can be overdriven like a transistor, or is there other ways to create distortion? Are there different configurations (like emitter-follower etc with transistors). What vts have the highest gain, which have the cleanest amplification. Basically, any and all info would be great. I have a basic understanding of electronics, but no education in the field. I would love to build affordable tube amps but its an "ancient" technology. Its kinda like saying i want to build Model As when everybody else is building Corvettes.  : )
Thanks for any help!
  • robogary
    robogary over 3 years ago +3
    tube amplifiers are still alive and popular, especially with electric guitars. I'd start with designs already proven, and experiment, before trying to design them. https://www.westernelectric.com/li…
    dougw over 3 years ago +3
    I built an experimental tube amp you can have a look at.... Tube Amp on a PCB
    shabaz over 3 years ago +2
    Hi, Valves/tubes are not something I know anything at all about, but I've definitely seen a lot of literature on it. There's a wealth of articles here: https://www.pearl-hifi.com/06_Lit_Archive/Lit_Archive…
    There's a wealth of articles here: https://www.pearl-hifi.com/06_Lit_Archive/Lit_Archive.html#Vol1
    Also, there are archives of electronics and wireless magazines online (some dating back up to 100 years), which will have many articles too, including audio amplifier construction projects.
    You could also examine vintage Hi-Fi circuits, since most of the old products had service manuals and many are online from various sources.
    If you're a beginner in electronics, then perhaps it is worth finding an old electronics textbook to learn from, although it may be an uphill struggle. I'm looking at a book called "Electronics Made Simple" by Henry Jacobowitz, which certainly has a section on amplifiers using tubes/valves, but I still don't think the book is that "simple", it's not an easy read. (example photos of pages below). Personally I think if you wish to use valves, it may be better to still begin with transistors, even integrated circuits such as op-amps and so on, i.e. follow a contemporary learning path, since there are lots of easy-to-follow resources for that, and besides, some tube amplifiers contain some semiconductors too.
  • robogary
    https://www.westernelectric.com/library
  • bidrohini
    bidrohini over 3 years ago
    For higher gain, you might consider tubes like the 12AX7 (ECC83) or 12AT7 (ECC81). For cleaner amplification, tubes like the 6SN7 or 6L6 can be suitable choices.
     Tube Amp on a PCB
    Jan Cumps over 3 years ago
    For DIY-ers, the books that Menno VanderVeen published with elektor have buildable projects.
    Some based on common historical designs, some new ones. With obtainable components.
    Basic electronics knowledge will suffice. Your maker skills are needed more than your theory.
  • colporteur
    colporteur over 3 years ago in reply to Jan Cumps
    Sorry JC I have to voice my concern. Vacuum tube builds require high-voltage. That is a little more for the novice DIY  to be aware of. I'm not saying it can't be done but does require a little more caution that building an Arduino project.
    • Vote Up -1 Vote Down
  • phoenixcomm
    phoenixcomm over 3 years ago
     Dimebaggins  Ok, so why would you want to "overdrive" a tube?? I have some stuff that glows :) And the idea is to always work insides its CURVE. That way nice clean sound.
    look at my preamp for my turntable.. Hiraga Preamp
    Jan Cumps over 3 years ago in reply to colporteur
    The elektor books handle that subject.
    DAB over 3 years ago
    We used tubes/valves when I went to Tech School in the 1970's.
    If you know transistor and FET theory, then you should be able to learn and use tubes/valves.
    Audio purists swear by them.
    Jan Cumps over 3 years ago in reply to DAB
    They were still on the curriculum when I studied electronics in the first half of the 80s. Although the only one that we really focused on for longer time was the - then still mainstream - CRT.
