Ask an Expert Forum Muscle to micro servo circuit
  • Replies 40 replies
  • Subscribers 333 subscribers
  • Views 5996 views
See a helpful answer?
Doppleganger
Doppleganger over 3 years ago
Morning all
So i started a Udemy class on Electronics and Robotics a while ago, and frankly I'm struggling. Apparently I'm great at building circuits from a photo or a video, but I have a lot of issues with schematics. Not super relevant to the post, but it may be helpful to you all to know where I'm coming from. I hope this isn't offside, but if some fine peeps could take a look at what I've built, see if I missed anything, or miss placed anything, that would be super helpful. Normally id just harass the instructor, but the class is 7 years old, and he is busy with other projects now and doesn't get back to me very often.
So, red, orange and yellow wires on the left go to the micro servo. Blue, green and yellow at bottom right go to the muscle sensors. Top positive and bottom negative are 6v, and the neg is also my ground (unsure about that, prof kinda skimmed that detail). Top negative is positive 9v, and bottom positive is neg 9v. Did that just to keep things straight in my head. I didn't have a 1000 cap, hence the stack of 3 in the middle of the board.
Main concern i have, that it dosnt work. Beyond that, from going through the class forum from many years ago, other students had a sh*t load of wires coming off the amp. I get that we all build differently, but just have 2, not 30. Maybe more weird than concerning.
Again, any insights are helpful.
    shabaz over 3 years ago +5
    Hi, You don't seem to have wired up pins 4 and 11 of the TL074 chip.
  • rad_bcit
    rad_bcit over 3 years ago +4
    Hello, I teach breadboarding skills and my immediate reaction to your photos is to say that the easiest remedy to your wiring issues is to tidy up the way you do your breadboarding. I would ask you to…
    michaelkellett over 3 years ago in reply to Doppleganger +4
    I looked through the replies you got and didn't find any at all with the phrases you quoted. It seemed quite a good response to me, you got a lot of good and relevant answers and the usual E14 diversions…
    shabaz over 3 years ago in reply to genebren
    Exactly as Gene says:
    The chip needs a power source, and the TL074 datasheet can also be examined, it too will indicate this.
    Sorry our replies crossed! : )
    genebren over 3 years ago in reply to shabaz
    No problem, I was just backing up what you found anyway.
  • rad_bcit
    rad_bcit over 3 years ago in reply to Doppleganger
    I find that the majority of times when I ask a student to tidy up their breadboards they find their wiring error during the process, so it's usually worth the effort.
  • Doppleganger
    Doppleganger over 3 years ago in reply to genebren
    Ballz. Thanks guys, i didnt even see that, i only saw the pin references on the outside of the "triangle". So then 6v runs the 555 timer chips and 9v for the 74 chip?
    What's the web link for the actual course?
    Their work is really poor. They have all their battery symbols with the wrong polarity. Also they don't know how to draw a decent schematic : (
    If you're looking for circuits with ~100% chance of working, then this website is really good, lots of beginner circuits: https://www.talkingelectronics.com/projects/50%20-%20555%20Circuits/50%20-%20555%20Circuits.html
  • md_steve
    md_steve over 3 years ago in reply to rad_bcit
    Wow, that is a nice example of a physical layout. I will strive to emulate this in the future.
  • Doppleganger
    Doppleganger over 3 years ago in reply to shabaz
    https://www.udemy.com/course/analog-electronics-robotics-learn-by-building/
    Ive felt that the teaching was lacking, but i attributed that to my lack of focus and previous knowledge, and the prof being so knowledgeable that he skips things he may think are "common knowledge". Either way i still think im winning, as i now know a butt ton more than i did before.
  • anniel747
    anniel747 over 3 years ago in reply to Doppleganger
    And they charge real money for that?
    Jan Cumps over 3 years ago in reply to rad_bcit
    For breadboards, I belong to the spaghetti crew. Once so often, when I make something that has to last for a bit longer, I'll do my best to keep things a bit organised. But usually, components come and go, are swapped out, .... A pure experimental work area.
