Ask an Expert Forum ECM motor module repair
  • Replies 25 replies
  • Subscribers 334 subscribers
  • Views 6717 views
See a helpful answer?
Siddan
Siddan over 2 years ago
imageimageHi guys I need help to fix my ECM blower motor module. It third time I am replacing motor on my water heater tank that works on natural gas. Each time the motor cost me 1850$ plus the labour to replace it.
The motor runs on 120v and speed regulated by contrôler by giving 36v duty cycle. The problem with the motor module is that it is stuck on high speed which is 100% duty cycle. I am sure it is one of the components on the module is defective that can replace to fix the problem. I don’t know how to upload the pictures.
  • anniel747
    anniel747 over 2 years ago in reply to Siddan +2
    Deleted
  • colporteur
    colporteur over 2 years ago in reply to anniel747 +2
    Great Share!
  • Siddan
    Siddan over 2 years ago in reply to michaelkellett +1
    I think so too. But these company make a lot of money on these part. First they sell you expensive appliances and then they rip you off on parts. Take a look at my receipt.
  • Siddan
    0 Siddan over 2 years ago in reply to Siddan
    Here is defective motor
  • Siddan
    imageimageHere is module picture front and back
    0 dougw over 2 years ago
    Check the tachometer carefully. If the tach signal is not working, the controller will likely try to apply full speed.
  • acdc90
    0 acdc90 over 2 years ago in reply to dougw
    Hello.i recon i can see connections for 3 hall effect devices on the bottom of board this would be feed back to ic. if 1 of these was faulty it would jerk or just pulse when power was applied ..
  • Siddan
    0 Siddan over 2 years ago in reply to dougw
    I checked and it has tech signal. Display shows at full speed which 9000rmp.
