Ask an Expert Forum Superior Electric Powerstat variable transformer 1296DU
  • Replies 8 replies
  • Subscribers 323 subscribers
  • Views 2603 views
See a helpful answer?
jmurray32168
jmurray32168 over 2 years ago
Is there an aftermarket device that can be added to a Superior Electric Powerstat variable transformer 1296DU that can digitally adjust the voltage wheel effectively making it an autotransformer?
    michaelkellett over 2 years ago +3
    The most common use of the term "autotransformer" is for a transformer where the primary and secondary are both just taps on the same winding. The 1296DU is a variable transformer (often a Variac in…
  • beacon_dave
    beacon_dave over 2 years ago +2
    There appear to be versions of the 1296DU that already have motors attached for digital control.
  • anniel747
    anniel747 over 2 years ago +1
    Deleted
  • anniel747
    0 anniel747 over 2 years ago
    [deleted]
  • kmikemoo
    0 kmikemoo over 2 years ago
    jmurray32168 In almost 40 years of working with electrical devices, I have not personally seen anything like what you are looking for.  It could be made, but I haven't seen a commercial product.  Good luck in your search. Thumbsup
  • jmurray32168
    0 jmurray32168 over 2 years ago in reply to anniel747
    no. I mean one that can digitally maintain a given input commanded voltage. If for any reason the input supply drift we have to manually adjust the wheel. I want to take us to the next level. I thought i had seen a mechanical device that can be added to these can automatically adjust the wheel based on any input drift/variation
    0 michaelkellett over 2 years ago
    The 1296DU is a variable transformer (often a Variac in the UK).
    From your question I suspect that you want to adjust it automatically. This is possible but has problems and is much less common now than it might have been 50 years ago.
    Mostly people use electronics to achieve the same result - you can buy adjustable AC regulators capable of handling power from a few watts to mega-watts.
    The problems with a motorised variable transformer are its slow response and short life (due to wear on the brushes)
    Can you explain what you want it for - it may be that there is a better solution.
    They are obtainable ready made but you could fairly easily modify a manually operated variable transformer for a one-off.
    https://www.ravistat.com/variable-auto-transformer-motorized-variac.php
  • jmurray32168
    0 jmurray32168 over 2 years ago in reply to michaelkellett
    Thank you very much. This is very helpful
  • jmurray32168
    0 jmurray32168 over 2 years ago in reply to jmurray32168
    we use them for product development and certification testing in a laboratory environment and have voltage regulation requirements. We make commercial refrigerated display cases and heated display cases. We also have an accredited lab.
    must maintain individual measurements +- 4% of rated voltage for DUT average over the test period and +- 2% of the rated voltage
  • beacon_dave
    0 beacon_dave over 2 years ago
  • kmikemoo
    0 kmikemoo over 2 years ago in reply to jmurray32168
    What you need is a powerline conditioner.  They are designed to do what you state and come in all sorts of sizes.
