Ask an Expert Forum XBox One S Powers down when HDMI Plugged in.
  • Replies 12 replies
  • Subscribers 333 subscribers
  • Views 3066 views
  • hdmi
  • xbox one s
See a helpful answer?
PMan976
PMan976 over 2 years ago
I have an XBox One S  with the following symptoms, I am hoping someone can point me in the right direction to narrow down the problem component/s
  • Unit powers up with no problem if the HDMI cable is not plugged in. Soon as I plug in the HDMI cable it shuts off
    • I have checked the connector and it is in good shape with no obvious faults
  • I can plug the cable into the XBox but not the TV and it will boot fine.
    • Soon as I plug it into the TV it shuts down
  • I have checked for shorts around the re-timer chip and can't find any
So any suggestions how I should proceed from here?
  • anniel747
    0 anniel747 over 2 years ago in reply to PMan976
    It's a known issue.
  • colporteur
    0 colporteur over 2 years ago in reply to PMan976
    Well it sounds like you have isolated it. I seem to recall HDMI has evolved and early implementation are slightly different than today.
    Have you tried different HDMI devices, old and new?
    Even if this test proves some things work and other don't, other than a firmware update I am at a lost to help you.
