Ask an Expert Forum EV_ICM-42605
  • Subscribers 333 subscribers
  • Views 1511 views
See a helpful answer?
EV_ICM-42605
cupracing
cupracing over 2 years ago
Hello, anyone has the datasheet or an electrical scheme of this board?
I am trying to communicate with that board with an esp32wrom devkit but i am not able to do anything. So i want be sure i am connecting or powering on it right
    dougw over 2 years ago +3
    Does this help? community.element14.com/.../AN_2D00_IVS_2D00_0001EVB_2D00_00_2D00_v1.4.pdf
  • Andrew J
    0 Andrew J over 2 years ago
    I typed EV_ICM-42605 into Google and the first link was: https://uk.farnell.com/invensense/ev-icm-42605/eval-board-3-axis-gyro-accelerometer/dp/3861382 which has a datasheet link.
  • cupracing
    0 cupracing over 2 years ago in reply to Andrew J
    Yes i have it, but it is the datasheet of the 42605 chip and not the devboard where is placed. I am looking to a datasheet referred to the breakout board
  • Andrew J
    0 Andrew J over 2 years ago in reply to cupracing
    I see, apologies.  I can only suggest going to TDK to see if they actually produce one.  If it isn't on their website already you may be out of luck - I can see they do a dev kit but that's obviously not the same.  I wonder if there are elements that are the same that can be, at least, interpreted from the dev kit download info?
    0 dougw over 2 years ago
    Does this help?
  • cupracing
    0 cupracing over 2 years ago in reply to dougw
    Not really because we have the newer version of that board that have the 42605 so it is a bit different
