Ask an Expert Forum Want to replace resistors myself, but need an advice
  • Replies 9 replies
  • Subscribers 333 subscribers
  • Views 2191 views
  • resistor
See a helpful answer?
weiyann83
weiyann83 over 2 years ago
based on documentation it show 2.2 1/2W J, not sure which resistor i need to replace? any expert can guide me?
elektrotanya.com/.../download.html
  • anniel747
    anniel747 over 2 years ago +1
    Deleted
  • weiyann83
    0 weiyann83 over 2 years ago
    The original resistor appears as shown, and I have observed that it consistently burns R7914 and cracks IC7905. Additionally, I have replaced the 3x power boards over the past four years.
    rioimage
  • JWx
    0 JWx over 2 years ago in reply to weiyann83
    If the IC cracks and resistor burns I would suspect IC failure (mosfet stuck in conducting state, leading to overheating and burning of the resistor). Maybe some overvoltage spikes? If it was the same board I would also suspect some other component failure that is killing converters - but as I understand power modules were replaced?
  • robogary
    0 robogary over 2 years ago in reply to weiyann83
    The resistor is likely the victim of another problem. This is the IC7905 spec.
    https://www.mouser.com/datasheet/2/328/tny263_268-1512708.pdf
    JWx has good ideas. Maybe it needs troubleshooting with a scope to see spikes or maybe one of the surrounding diodes has failed open.
  • anniel747
    0 anniel747 over 2 years ago
    [deleted]
  • weiyann83
    0 weiyann83 over 2 years ago in reply to anniel747
    Is not common I don’t see element14 got sell this type of resistor, if you can provide link which type of fusible resistor very much appreciate.
  • weiyann83
    0 weiyann83 over 2 years ago in reply to robogary
    Ic i able to find from element14, but fusible resistor same spec i cant find from the element14 any alternative resistor fusible we can use?
  • anniel747
    0 anniel747 over 2 years ago in reply to weiyann83
    canada.newark.com/.../97K6497
  • acdc90
    0 acdc90 over 2 years ago in reply to weiyann83
    please check on the secondary of the transformer for shorts across diodes  etc
    it sounds like each board is less than a year old ( so not warranty)
  • phoenixcomm
    0 phoenixcomm over 2 years ago in reply to weiyann83
     weiyann83 could be that  as JWx suggested the MOSFET is stuck ON. One thing you could do (a little nuts)  2.2Ω 5W 5% fusible resistor. and mount it off the board maybe even bend a small aluminum into a U-shape and clamp it to the resistor. personly you could use a hose clamp BYW heat compound is used as well. You realize that this is OVERKILL ~~ Cris
