Ask an Expert Forum Identify another SMD
  • Replies 10 replies
  • Subscribers 320 subscribers
  • Views 2689 views
See a helpful answer?
acdc90
acdc90 over 2 years ago
Here is another SMD diode i want to identify i think package DO214AA used with IR2110 with 380v across ic
  • javagoza
    javagoza over 2 years ago in reply to acdc90 +6 suggested
    use google lens Then in the Internet Archive usually you can browse old manufacturers site and datasheets Wayback Machine (archive.org) Ultrafast Rectifiers (archive.org) Rectifier Products…
    dougw over 2 years ago +1
    General Semiconductor logo according to Google image search - now owned by Vishay Siliconix
  • acdc90
    acdc90 over 2 years ago in reply to koudelad +1
    THANKS i am going to order MURS160
    0 dougw over 2 years ago
  • koudelad
    0 koudelad over 2 years ago
    At least two devices have MJ device marking
    MURS360: here is a datasheet: www.vishay.com/.../murs340.pdf
    MURS160: www.vishay.com/.../murs140.pdf
    • Vote Up -1 Vote Down
  • anniel747
    0 anniel747 over 2 years ago
    MURS360 if DO-214AB. MURS160 or MURS260 if DO-214AA.
  • koudelad
    0 koudelad over 2 years ago in reply to anniel747
    Not MURS260, it has M2J device marking, see here: www.vishay.com/.../murs240.pdf
  • anniel747
    0 anniel747 over 2 years ago in reply to koudelad
    Not in the General Semiconductor era.
  • koudelad
    Can't find a datasheet that would support the claim.
  • acdc90
    0 acdc90 over 2 years ago in reply to koudelad
  • acdc90
    0 acdc90 over 2 years ago in reply to acdc90
    WHEN I tried using google image on diode or on just the symbal i got no results.so is there anything else to get that to work?
  • koudelad
    0 koudelad over 2 years ago in reply to acdc90
    Image search is currently pretty basic. If you provide a picture of a larger PCB area, it just finds some general electronics. If you focus only on the logo, it tries to find similar artefacts like jewelry or tatoos etc. I guess it would work better if a company logo on a building was provided or something similar. Currently it is only interpreted as some curves on some surface, which is pretty much anything.
  • javagoza
    0 javagoza over 2 years ago in reply to acdc90
    use google lensimage
    Rectifier Products (archive.org)
    • Vote Up +6 Vote Down
