Raspberry Pi Forum assembly
  • Subscribers 671 subscribers
  • Views 1172 views
assembly
Bomull
Bomull over 1 year ago
I am rather new to this but have mounted the 7’’ Touchscreen Display with my PI4 and added a virtual keyboard. Everything works fine. But now
I have received a dAISy HAT AIS receiver from Wegmatt that I plan to use on the unit but realise the the 2 jumper cables for the screen to the connector on the PI
are blocking the mount of the  HAT card on the same connector. Anyone had a simmilar problem? As I understand so are the two jumpercables to the screen for
power, can I take that somewhere else on the PI?  Thankfull for suggestions and inputs.
//Bo
    0 shabaz over 1 year ago
    Hi Bo,
    See here for a possible solution:  Raspberry Pi 7” Capacitive Touch Display: Assembly and Enclosure
  • Bomull
    0 Bomull over 1 year ago in reply to shabaz
    Thanks!  I had that in mind for a minute but was hoping to avoid using the soldering iron…
  • fmilburn
    0 fmilburn over 1 year ago
    I have used dAISy with a Raspberry Pi hat and the Pi display in the past and even made a short post about it here on element14. I don’t remember having problems or what I did to get it running but unfortunately made no documentation.  I suggest you contact Adrian at Wegmatt as he probably has seen this before and is responsive to customer questions.
  • beacon_dave
    0 beacon_dave over 1 year ago in reply to Bomull
    If you don't want to solder onto the Pi then you could use a stacking header with a bit of stripboard to give you some additional pins.
    If you don't want to solder at all then perhaps use something like this:
    https://www.amazon.co.uk/Connectors-Raspberry-40-pin-Expansion-RAS-GP02/dp/B07MCW4KCM?th=1
  • beacon_dave
    0 beacon_dave over 1 year ago in reply to beacon_dave
    Stacking header:
    https://www.adafruit.com/product/1979
    Stacking header with PCB breakout:
    https://shop.4tronix.co.uk/cdn/shop/products/bkt03_1024x1024.jpg
    (could use stripboard instead of the PCB)
  • Bomull
    0 Bomull over 1 year ago in reply to fmilburn
    Thank you so much!
