Ask an Expert Forum We need real time temperature monitoring to turn on and off a device. Can the PT-104 give us real-time temperatures so we can do that?
  • Subscribers 333 subscribers
  • Views 985 views
See a helpful answer?
AriTL
AriTL over 2 years ago
    shabaz over 2 years ago +2
    Have you checked the product specification sheet? What part of the spec were you unsure about? Only you know your full requirements (which you've not revealed), so you need to check against the spec sheet…
    shabaz over 2 years ago in reply to balajivan1995 +2
    He's referring to a PT-104 logger. The logger does not need pairing with any chip. It directly accepts probes.
    0 shabaz over 2 years ago
    Have you checked the product specification sheet? What part of the spec were you unsure about? Only you know your full requirements (which you've not revealed), so you need to check against the spec sheet to make the determination.
  • balajivan1995
    0 balajivan1995 over 2 years ago
    We have used a PT 100 based temperature sensor in our project. To improve accuracy you need to pair it with a chip like this one learn.adafruit.com/.../overview
    • Vote Up -1 Vote Down
    0 shabaz over 2 years ago in reply to balajivan1995
  • balajivan1995
    0 balajivan1995 over 2 years ago in reply to shabaz
    My bad. I saw the words PT104 and temperature together and assumed it is similar to PT100 and PT1000 standard sensor. I should have checked.
