Ask an Expert Forum Power Supply
  • Replies 10 replies
  • Subscribers 332 subscribers
  • Views 1556 views
See a helpful answer?
Power Supply
Muthahar786
Muthahar786 over 2 years ago
The Tenma power supply turned off when I switched from 230V to 115V with 230V connected.
it is not getting ON. Not sure if fuse has failed.
Any idea how to make it ON?
  • Muthahar786
    Muthahar786 over 2 years ago +3
    Thank you all for the responses. With fuse change, the power supply is now working.
  • md_steve
    md_steve over 2 years ago +1
    Please give us the model number.
  • aswinvenu
    aswinvenu over 2 years ago +1
    Did you see magic smoke? If not check the fuse!
  • md_steve
    0 md_steve over 2 years ago
  • aswinvenu
    0 aswinvenu over 2 years ago
  • kmikemoo
    0 kmikemoo over 2 years ago
    Another component to check is the slide switch itself.  Deenergized, of course.  The physical construction of those switches isn't robust when it comes to dealing with arcing switching.  The good news is that they are readily available (in many cases) and are not hard to replace.  Good luck.
  • dang74
    0 dang74 over 2 years ago
    I am not familiar with this specific power supply but I think setting the switch to 115V while it's still connected to 230V would expose its internal power conversion circuitry to twice the voltage it's designed for.... hopefully it isn't damaged and it's a simple matter of changing a fuse.
  • acdc90
    0 acdc90 over 2 years ago in reply to dang74
    i expect this has a switch mode supply then if it designed properly it would have some Gmov (varister)
     if your lucky 2 of those and a fuse and your away.
    a lot of time i disable that switch
  • Muthahar786
    0 Muthahar786 over 2 years ago
    TENMA_72-13350
    Model no
  • aswinvenu
    0 aswinvenu over 2 years ago in reply to Muthahar786
    Did you check the fuse?
  • kmikemoo
    Muthahar786 While not exactly your power supply, this post from two years ago may also help you.   Tenma Power Supply Firmware & Schematics (72-13300, 72-13310, 72-13320, 72-13330)
  • Muthahar786
  • dang74
    0 dang74 over 2 years ago in reply to acdc90
    I'm crossing my fingers too.
